Go to Post Evolution is innovation. - Chris is me [more]
Unread 30-04-2007, 15:06
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Glove Control System?
Originally Posted by whytheheckme View Post
the only microprocessor that you can have hooked to the OI Inputs is the IFI (crosstheroad) USB Chicklet.
Obviously, this year's rules don't apply to future games, but can you back up this claim with the 2007 rules?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 30-04-2007, 15:54
With ease.
<R83> All equipment connected to the joystick ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the joystick ports. Portable computing devices can not be connected to joystick input ports on the Operator Interface. Powerpassive devices (e.g. joysticks that draw their power solely through the Operator Interface joystick port) are permitted. The one exception to this rule is Innovation First Incorporated USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to the joystick ports of the Operator Interface. If used, this USB adapter must be powered with a 7.2V battery similar to the back-up battery. Teams can not use power from the competition port or any other source to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a match.
Unread 30-04-2007, 16:04
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally Posted by Alan Anderson View Post
With ease. <R83>...
All that says is that it can't be powered externally. It is quite possible to run a microcontroller off of the power available on the joystick port; we did it successfully this year.
Unread 30-04-2007, 17:33
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
So yeah, the processor would have to accept the power from the joystick port, and so would the glove (which is USB complient.. a lot of power). Also, I think the processor would be considered as a Portable Computing Device.
Although, perhaps an exception could be made with the GDC for this device in particular. Kind of like DDR pads don't officially follow the rules, the GDC has allowed them. I think the intent of this rule is to prevent you from plugging in a computational aid into the joystick ports to run your bot (like somthing plugged into your dashboard that is getting real-time info, or a laptop that can tell the robot what the best place to score is, etc.)
Jacob
Unread 30-04-2007, 18:04
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
This is what I was getting at. The traditional (and sensible) interpretation is that PICs are not computers.
_
Unread 30-04-2007, 18:07
AKA: Jacob Komar
Perhaps, but there is still the power issue. I'm sure this thing consumes quite a bit of power (there is a wireless component (IR I believe) to it as well)...
Isn't that another rule somewhere? No wireless stuff other than IFI 900mhz? It's only IR (I think), but it still may be considered wireless.
I would love to be able to do this, but not if I build it and found out I can't use it.
Jacob
Unread 01-05-2007, 17:30
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Assuming that it's powered solely by USB... the most it can draw is 5v @ 500mA if I'm not mistaken. That, and IR LED's draw very little amperage (as do most LED's). Now, if it's legal for competition? I have no idea.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 30-04-2007, 18:39
Software Engineer
Rookie Year: 1995
That is my opinion as well, and seems to be backed by various FRC Q&As. This one from last year (I know, I know - last year is not this year) said that translators were not considered portable computing devices. This one from 2007 indicates that any USB->15 pin adapter (if such a thing other than the Chicklet exists) is legal as long as it does not draw external power. Logically, that would extend to any sort of adapter that does not require external power. Attached is a picture of our OI with the two adapter boards that we designed and used.
Regarding the original topic, if it's USB couldn't you just use the Chicklet and be done with it?
Unread 30-04-2007, 19:09
All that [<R83>] says is that it can't be powered externally. It is quite possible to run a microcontroller off of the power available on the joystick port; we did it successfully this year.
I always thought a plugged-in microprocessor matched the idea of a "portable computing device". However, it seems the Q&A draws the line at "external power source" rather than at my idea of "computing device".
Unread 01-05-2007, 09:07
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Also, HOT had a glove in 2005, but im not sure what they used it for either.
Min-Max to the Max!
Control System Mounts? archiver 2001 11 23-06-2002 23:33
Control System archiver 2000 0 23-06-2002 22:51
control system archiver 2000 1 23-06-2002 22:04
its all in the glove! dandaman Technical Discussion 14 24-02-2002 10:59
Building a control system Katie Reynolds Technical Discussion 3 16-11-2001 09:34
