Go to Post It doesn't make a team better if they have just one sponsor or if they have 100 sponsors. However, you should commend a team who struggled to pay the bill with a list of sponsors one hundred long for showing their strength, perseverance and love for participating in the FIRST robotics program. - MikeDubreuil [more]
Unread 01-05-2007, 22:16
CraigHickman
Posts: n/a
pic: The Beast Box
Unread 01-05-2007, 22:17
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Re: pic: The Beast Box
Is there any reason why you're only using (it seems) one motor per side? Or is there a second set of gearboxes on the other side of the chasis?
Team 177 - Bobcat Robotics
Unread 01-05-2007, 22:19
CraigHickman
Posts: n/a
There's two motors there, you just can't see the other one, as it's directly below the one on top.
Unread 01-05-2007, 22:29
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Sweet gearbox!
You might want to consider using one pneumatic cylinder instead of 2. If you put one in the middle and hook both shift bars to it, you get the same effect as two, but use half the air. (unless of course you're planning to use a compressor or utilizing the space between the two cylinders)
Just a thought; our team did that with our pneumatic shifter this past year and it worked great. It helped us with weight by eliminating the extra cylinder and potential air tanks.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 01-05-2007, 22:35
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
I notice that you are using 0.25" face width gears in the transmission. Did you already do the calculations for this and it will work? I am currently thinking on a single speed transmission that is small and light weight, and using smaller face width definately would save weight.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 01-05-2007, 22:38
CraigHickman
Posts: n/a
I tried that on my 05 bot, and wasn't too pleased with it. It takes a bit more tuning to get the drive system to shift evenly, which makes driving a bit of an issue. Plus, each cylinder is a half inch stroke, 3/4 inch bore, so the air useage is minimal.
Yeah, these are 24 dp gears. The pinion and the first gear are 20, as that is the gearset that ends up being hit with the most force and wear in a drive system of this type. They'll work just like 20 dp, but they're smaller.
Unread 01-05-2007, 23:00
Gabe's Avatar
Sorry, I noticed that you appear to have quarter inch face width gears in your transmission. I woud like to know if you did any gear strength calculations with this decision, or if you are just making an educated guess. Hope that was clearer.
Unread 01-05-2007, 23:02
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Sweet gearbox!
not to hi-jack the thread, but could you post the drawings of your set-up. it sounds very interesting.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 02-05-2007, 00:36
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Why 7075 plates? And why only 1/8"?
Also, you may want to run some lewis bending numbers on those 24dp gears... you may have already, but at first glance it looks iffy. Depends entirely on the material, though.
Otherwise looks good!
Edit: Also, you said you used 20 DP on the initial reduction off the CIMs, and jump down to 24 on the other stages? That is counter intuitive to me, as you are gearing it down each stage you move away from the motor, putting more torque through the teeth of those gears.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 02-05-2007, 22:54
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
I think because it's strong enough. We had the tracks this year and 1/8" is plenty enough to hold everything together. No point making them thicker if it's not needed.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Unread 02-05-2007, 22:58
AKA: Yi Li
Team Role: Operator
Those two support beams running through the center, are those 3/4" L's? or are they squares?
Unread 02-05-2007, 23:06
AKA: Yi Li
Team Role: Operator
Instead of lining up the motors perpendicular to the transmission, why not put worm gears on them and line them up parallel to the transmission? This way, it’ll give you more usable space and the tracks would be self-locking. No more rolling down the ramps after the power is cut. A robot with self-locking tracks from Outback would not be moved by anything at anytime unless it wants to.
Unread 03-05-2007, 01:04
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
Why dont you integrate the tracks into the total length of the frame? Make them removeable but you could extend them the entire length & have them detach as a single unit for easy working while the rest of the team works on whatever mechanism is on top of the bot. In the drawing the plates just get welded onto the 2x1 (guessing) at the ends but I think you might run into issues with that.
team4element
Unread 03-05-2007, 01:59
CraigHickman
Posts: n/a
I personally have no experience with worm gears, and so venturing there on a system this expensive would not be a good use of budget for me.
Those are 1x1 box extrusion pieces.
I personally have no clue how to run numbers like that. I'm a junior in high school, and if I learned to do that, I'd be seriously happy (so if you wanna teach me, then yay!). But I'm going from experience here. In the past, when we take apart an old tranny, the pinion set is always the one with the most wear and tear on it, and so I've kept that one nice and buffed up.
They actually are removeable, by two bolts per end of the tread, similar to what 997 did this year. However, I'm too lazy to put those bolts in at this CAD stage.
Unread 03-05-2007, 02:24
Engineering Mentor
FRC #0254
There was an excel spreadsheet posted here a few years back [only last year actually] that took the basic lewis bending formula and had a few boxes where you input the material, torque input, and face width, etc and it gave you aprox safety factors.
For those unfamilar with strength of materials and the like, it was a very good resource.
Let me try to find it...
Edit: Here it is... http://www.chiefdelphi.com/forums/at...3&d=1137918029
Thank Matt Adams for that one!
-Travis Covington
pic: Pink Swamp Beast in action Joe Matt Extra Discussion 0 27-04-2007 15:23
pic: Greg And The Beast jade_team_73 Extra Discussion 24 27-02-2007 20:25
Gas prices drop because of the BEAST (71)? Greg Needel Chit-Chat 14 25-05-2006 05:05
Anyone got a video of the Beast in 2002? George A. General Forum 10 17-01-2005 10:34
pic: The BEAST Goes Down! CD47-Bot Extra Discussion 5 22-04-2004 11:14
