Go to Post PLIERS: Used to round off bolt heads. - Andy A. [more]
Unread 01-05-2007, 23:41
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: Voltage regulator--how to mount?
you know Ive used the 7805 for lots of projects(usb car charger, loads of ttl circuits off of 9/6v), and Ive never had a problem with over heating(not to say it doesn't get hot just that it doesn't seam to be a problem). so you can put a heat sync on it if you'd like but I think that may be over complicating things.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
how to mount a lcd display onto a robot mechanicalbrain Electrical 9 07-09-2005 20:57
how do you mount the accelerometer? team 507 Control System 4 10-02-2005 07:54
Voltage Regulator Robby Electrical 5 18-01-2005 07:50
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
