Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 01-05-2007, 22:32
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Question Portable Racks
Hi,
My team didn't get the time to build a practice rack during the build season, but we want to build one now in order to demo the robot at schools and for sponsors. We were originally going to make a partial rack that would be the regulation size 10 ft tall, and one or two legs wide, and use the materials suggested by first. Now we are thinking about making a telescopic rack that would collapse for easy portability. Has anyone else made somewhat portable racks, what do they look like (aside from what it's supposed to look like), and how much it cost to build?
Thanks,
Anish Simhal
Team 1123
Unread 01-05-2007, 22:35
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
Re: Portable Racks
I would be careful making it 10 feet tall. There are a lot of places you may demo that don't have ceilings that tall. However you end up making it, I would suggest having it so that it doesnt have to go all the way up to 10 because that was part of our problem, our rack didn't fit anywhere!
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 01-05-2007, 22:36
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Re: Portable Racks
We used PVC tubes to create a rack we could break down and put up in around 15 mins. We found the light was too heavy and would bend the PVC but we corrected that by tying it down and eventually actually used a sort of "bow" to pull it straight.
It's hard to explain how we got it to stand straight so I'll see if I can get some pictures tomorrow. Some people may have invariably taken pictures of the rack we had at the regionals because it was often set up by the practice field and we would let other teams use it if they wanted.
Unread 01-05-2007, 22:39
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Re: Portable Racks
What seems to have worked for some teams is to use 2005 goals and strap a piece of PVC on the top. Really, anything with a decently triangular base which PVC will attach to is an ideal solution in my mind. (Collapsable is a bonus)
Team 177 - Bobcat Robotics
Unread 02-05-2007, 00:02
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Portable Racks
So I just had an idea about this. Make a basketball goal. Tear the top (basket) off and screw a spider leg on 3 sides 90 degrees apart around the circle. If you do it right, you can put one leg on each height on three different angles and it will be easy to fold up because all you have to do is turn the spider vertical and you can move it easily because basketball goals have wheels at the bottom. I will post a picture of what I am talking about soon if you don't get the idea. Otherwise, if you still have tetras, I hear they work great!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 02-05-2007, 01:05
run the trap!!!
Team Role: Human Player
Re: Portable Racks
We don't have enough room for a rack (our practice area is in a hall-way ) so we had to build something that could be folded up every day after practice.
We built this in less then an hour and it served us very well all season!
Basically its three spider legs bolted to a 2x4. When you want to set it up you just clamp the ends of the spider legs to a building or pillar. When you want to disassemble it you just take off the clamps and it folds up into a nice bundle.
Hope that helps! PM me for more info.
-Philip J. Fry
Unread 02-05-2007, 06:33
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Re: Portable Racks
When we demoed for the senator, we built a smaller structure that can barely be defined as a "rack." It was basically a rectangle of 2x4's with some additional supports on the ground (for balance) with two of the standard spider legs (low/mid) hanging from it. It worked fairly well for its purpose, and was easily transported from one place to another.
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 02-05-2007, 08:13
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Re: Portable Racks
one way to just have a really easy place to score ringers is just to create a pvc pole that only has a base like a post in the ground. It isnt a rack but it would be very portable and a really easy fix.
Unread 02-05-2007, 12:46
TKM.368's Avatar
TKM.368 TKM.368 is offline
AKA: Osa
FRC #0368 (Team Kika Mana | Tiger Power!)
TKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond reputeTKM.368 has a reputation beyond repute
Re: Portable Racks
Similar to what other people have previously mentioned. One of our mentors graciously built this for us at the last minute when we needed to go on TV last month. Sorry the screen caps aren't such great quality.
ID:	5502  Click image for larger version
Make a difference - VOLUNTEER!
pic: Portable Operator Control falconmaster Extra Discussion 1 15-02-2007 13:36
Rack and Roll D&D: RACKS & ROBOTS! platypus Games/Trivia 2 07-02-2007 19:33
Portable IDE Nitinol Programming 14 04-02-2007 03:23
do the racks move? groves Rules/Strategy 34 11-01-2007 14:03
Portable 12V Power Supplies? archiver 2000 2 24-06-2002 00:19
