Go to Post If an alternate is used, all four teams are equal members of the alliance. (Trophies, trips, bling, book tours, custody of the children etc.) - Btower [more]
Unread 01-05-2007, 17:00
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
mecanum vs. omni
hey everyone!
we (1565) are working on developing a drive system for next year. so far we're thinking of omni wheels (we almost did them this year). i don't know much about these drive systems, and i was wondering about the pros and cons of omni vs. macanum wheels.
Unread 01-05-2007, 17:38
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
Re: mecanum vs. omni
Omni wheels are cheaper, and allow for truly omni-directional motion. The programming is really not that difficult. My team built a holonomic drive train this year and it was one of the best decisions we've ever made.
Unread 01-05-2007, 17:55
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Assuming that you are using off the shelf components a Mecanum drive is easier to make. Omni-Drives require precise angles (60° for a Kiwi and 90° for a Holonomic) and if you are not near perfect your robot will have some strange driving characteristics. Also it is much easier to climb ramps with Mecanums. To my understanding Mecanums are also more efficient in forward and reverse directions (like a normal wheel) while still giving you lateral mobility. Omni-Drives have a much lower efficiency (~50%) in all directions but they will give you true omnidirectional motion. Also Omni-Drives require much more skill to drive than a Mecanum Drive. Still, you should test out both drives to see what works better for your application and to suit the game.
-Dustin Benedict
Unread 01-05-2007, 18:00
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I think the one major advantage that mecanum wheels have over omni-wheels is that they can fit in a normal frame set up. Omni wheels have to go on in a way that requires more fabrication while you can simply drop some mecanum wheels into a kitframe.
Unread 01-05-2007, 18:02
4throck 4throck is offline
FRC #1418 (Vae Victus)
4throck is a name known to all4throck is a name known to all4throck is a name known to all4throck is a name known to all4throck is a name known to all4throck is a name known to all
The one real problem with these drives that we discovered was victor bias. The values that come out are not symmetric, linear, or normal by any means. We ended up using look up tables, ask Kelly for more information about how we did it.
And for the record, it's not hard to line up the wheels at angles that are close enough to 90 for all practical purposes.
Unread 01-05-2007, 18:09
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
I have to disagree. Mecanum wheels tend to wander side-to-side when trying to negotiate a ramp, even one that is relatively small. One of our alliance partners at nationals struggled to get on our lifts which had 1.5" (very low) ramps. Their robot had difficulty driving in a straight line, something that was required to get up on our lifts.
Perhaps the problem was with some other component in the drive system of their robot but it has caused our team to shift our focus from mecanum to crab for experimentation.
Spend the 2 cents wisely!
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 01-05-2007, 18:11
FRC #1418
Actually, if you understand the math, it's okay if your angles are not perfect, as it's fairly easy to fix in code. The ease of climbing ramps is determined by the type of omni wheel you buy. Unfortunately, most of the off the shelf omni wheels our team found had lousy traction, although it would be possible (mabye not feasible?) to manufacture your own.
Unread 01-05-2007, 18:19
tseres's Avatar
also, programming wise, which is easier? i'm the new team programmer...
i don't know why, but for some reason i like the idea of mechaum wheels better than omni....maybe they look like they get better traction (i dont know if they do). we originally wanted a crab drive, but today we came to the conclusion that omni would be easier and better for our first time. i'm just wondering the differences so that we make the right choice...
Unread 01-05-2007, 18:24
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That's a lot of generalizations.
Mecanum drives require just a much precision to make as holonomic (omni/kiwi) drives, but instead of worrying about how to place your wheels radially, you have to place them in facing the same angle (if this is off, you will once again experience incorrect driving, unless you account for it in programming). In addition, like a mecanum drive, you can account for any imperfections in wheel placement in a holonomic drive with programming.
In general cases, Mecanums are capable of climbing inclines/steps/bumps better than most holonomic drives, but it is possible for holonomic drives to climb them given the right wheels and/or suspensions (and the size of the inclines/steps/bumps).
Mecanums and Holonomic systems aren't really any more efficient than eachother, they just function differently. Assuming a 45º roller placement on a Mecanum wheel (standard for FIRST purposes, used on the AM Mecanums), a Mecanum wheel delivers about 70% ([square root of 2]/2) of the force applied in both the "vertical" and "lateral" directions. Each omni-wheel delivers 100% of the force in the direction it faces, but the over-all efficiency of the drive depends on the number of wheels used, direction of travel, and rotational movement. Basically, a mecanum system uses angeled rollers and straight wheels to achieve the same goal a holonomic system uses straight rollers and angeled wheels for.
As for the driver skill, I fail to see how one would be harder to drive than the other (when programmed properly). A common control style is using a single joy-stick to control the lateral movements of the robot (using both the x and y axis) and either a z-axis or a knob (pot) to control the rotational motion. I have seen this system applied both to holonomic and mecanum drives (and have driven it with a holonomic....with ease).
Neither system is truly "better". They are very very similar systems, that function on the principle of vector translation. The programmers for either system should have a firm grasp on vectors and (preferably) kinematics in general. The efficiencies, torque, speed, traction, agility, cost, weight, size, and complexity vary greatly on the exact system you use (wheel choice, wheel placement, programming ability, etc.). Ideally both systems should have some form of suspension to ensure that all wheels remain in full contact with the driving surface, but teams have succeeded in the past with-out them.
I'd suggest you consult teams that have used each system for tips and lessons learned, as well as reading Ian Mackenzie's whitepaper on the kinematics of omni-directional systems. http://www.chiefdelphi.com/media/papers/1836
Some existing threads on both systems:
http://www.chiefdelphi.com/forums/sh...hlight=mecanum
http://www.chiefdelphi.com/forums/sh...highlight=omni
Programming emphasis:
http://www.chiefdelphi.com/forums/sh...ad.php?t=36205
http://www.chiefdelphi.com/forums/sh...092#post421092
Unread 01-05-2007, 19:26
tseres's Avatar
one more thing: where can mecanum wheels be purchased and roughly how much do they cost?
Unread 01-05-2007, 19:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
http://andymark.biz/am-0083.html
$375 per set (plus shipping)
Unread 01-05-2007, 20:09
From the point of view of the software, a straightforward Mecanum drive is identical to a typical omniwheel setup with 45-degree-angled wheels at the corners. They're equally easy.
On the other hand, they're equally difficult. To be able to drive a holonomic platform easily requires tight feedback control of wheel speed. Giving the driver complete responsibility for motor power is simple, and works fine for demonstrations, but if you want to do something tricky like climb a ramp it's probably going to have to be a bit fancier.
Unread 02-05-2007, 17:38
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Our team has used a holomonic for the last 3 years. I would strongly suggest that you use some for of feedback is this system. We had no luck with it untill we put a gyro in the base. This would apply for both holomonic and mechanum because both depend on the motor speeds.
In terms of which to use I would suggest holomonic much more than mechanum. I don't like mechanum for two reasons: 1. Much more expensive 2. because of the roller set up on mechanums, even when driving forward or backward there is a side force placed on the bearings. This year we could find a washer to captivate our wheel (all of the lateral force on the wheel is placed on this piece). We decided to cut them on a laser engraver out of 16th inch acrylic (shatter prone) and we have had no problems with the wheels or anything to do with the drive train. I could not have done this on a mechanum because, in the most simplistic view, for every pound of forward force there would be one pound of sideways force and the washer would have shattered the first time the machine took off.
Just a couple of thoughts
Unread 02-05-2007, 17:41
tseres's Avatar
just surious, why did you use the gyro? i mean, why is it needed? can't you just do everything in the programming?
Unread 02-05-2007, 17:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It depends on the style on control you want really. For a robot-centric drive (push up on the joysticks, the robot moves to its "front"), a gyro isn't always necessary, but for a field-centric (push up on the joystick, the robot moves away from the driver), a gyro, accelerometer, and/or other sensor packages are almost required.
Mecanum Defense MAteo9944 Rules/Strategy 20 04-04-2007 17:33
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Rob2713g Technical Discussion 13 03-11-2006 14:16
Omni Silent_Stryker Championship Event 4 21-04-2006 20:24
omni wheel instead of mecanum wheels Leav Technical Discussion 4 15-01-2006 18:53
