Go to Post My favorite is always "The Next One!" - Bill Moore [more]
Unread 02-05-2007, 18:54
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Vex Programming Question
Originally Posted by Kingofl337 View Post
easyC 1.x never had any code to monitor the transmitter. The problem you were having was probably using "PWM Control".
Found inside the "RC Control" pallet Instead of a motor block. PWM was in a loop with the controller functions so it may have acted oddly without the controller turned on. This was later eliminated in V2 and later versions of easyC.
Also, V5 is the correct master code version to use with easyC 1.x
OK - let's notice that I didn't say that EacyC 1.X monitored the transmitter.
I said that the transmitter had to be turned on before some programs (at least one) written using 1.X could work.
And I think you just agreed with me.
Acting "oddly", in my case, meant sitting there like a lump, cycling through my infinite loop just fine; but not issuing any useful (useful to me) commands to the PWM outputs, until the transmitter was turned on. It was a very frustrating night (and morning).
If I remember correctly the PWMControl documentation did not mention any situations in which one might expect odd behavior.
Blake
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
VEX programming Gene F Programming 14 08-08-2006 22:21
Programming VEX Controller HRobotics Programming 4 21-03-2006 23:25
Vex like programming? Morenoh149 Programming 2 09-07-2005 22:32
Vex Programming foobert FIRST Tech Challenge 3 24-06-2005 01:09
