Go to Post Life is totally random and there's nothing you can do to change that. - kristen [more]
Unread 01-05-2007, 11:43
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
Requesting 2006 default code
Hello, I am programmer on team 1203. We are currently trying to test some code but we don't have the default 2006 code anymore. If someone could please upload it and post a link or point me to a place where i could find it.
Thank you
-CyDrive
Unread 01-05-2007, 12:02
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Re: Requesting 2006 default code
Here is a link to it on the IFI web site.
http://www.ifirobotics.com/docs/lega...-2-28-2006.zip
Good luck,
Greg
Unread 01-05-2007, 12:04
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Just curious, why '06?
I'm sure there's a reason, but I'm pretty bored today
Jacob
Unread 01-05-2007, 16:48
CyDrive's Avatar
Thank you very much for the code. The reason we need 2006 is because our 2007 robot is just a deployable ramp. It does not move or do anything else but open up and drop a ramp. So in order to properly test code we had to use last years robot and didn't want to go mixing code around.
Thanks again
-CyDrive
Unread 01-05-2007, 19:53
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
The robot controllers from 2006 and 2007 are basically the same. The 2007 default code will work on your 2006 controller.
Unread 01-05-2007, 20:05
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
You might also be interested in kevin watsons 'default' code..
kevin.org/frc
Unread 02-05-2007, 09:17
I remember your team's chant in the stands at SBPLI during Finals:
"Push the Button!!!"
Unread 02-05-2007, 13:48
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
i believe that the code from 2004 is also the same.....i think....
Unread 02-05-2007, 14:57
The part of the code that we get to customize is close enough to the same as to make no practical difference. However, the project settings and the precompiled code libraries are different, because the processor is a different part.
The 2004 system is slightly different from the 2005 system, but the code should be compatible between them. I believe the 2006 and 2007 systems are identical to each other. The 2006 and 2007 systems have library files in the default project that differ from the 2004 and 2005 systems. The differences are documented in the 2007 default code file named "Using_a_2005_FRC.txt".
Unread 02-05-2007, 16:08
tseres's Avatar
the 2005 system is also the same as 2007....unless the actual processor itself is different....i've programmed both and they work the same.
Unread 02-05-2007, 18:49
The 2004/2005 controllers both have a PIC18F8520
The 2006/2007 controllers use a PIC18F8722
The difference is more memory (and some silicon errors).
Variable Space - PIC18F8520 2048 bytes + 1024 bytes EEPROM
Variable Space - PIC18F8722 3936 bytes + 1024 bytes EEPROM
Program Space- PIC18F8520 32K
Program Space- PIC18F8722 128K
(see http://www.ifirobotics.com/rc.shtml#Specifications)
Unread 03-05-2007, 01:55
CyDrive's Avatar
Yeah, What we originally had was 2005 code running on a 2006 robot which would run but not properly. Though at least our 2007 code works on the 2006 robot.
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
7.20 compiler and 2006 default code pagemauck Programming 12 20-04-2006 13:51
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Where to get the 2006 default code? Eldarion Programming 12 15-01-2006 15:48
