Go to Post Rain? Prepare for Armageddon to strike when you go to St. Louis. Two years in St. Louis. Two years of Tornado scares. Tis the season. - Koko Ed [more]
Unread 03-05-2007, 09:41
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Question Power suppy for dashboard.
I am trying to figure out a way to power our dashboard without having to plug it into an outlet. Does anyone have any ideas?
We are desperate, we have a demonstration for a fund raiser tomorrow and there is limited to no outlets available.
Unread 03-05-2007, 09:45
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Power suppy for dashboard.
If you are refering to the OI, you can tether it to your bot with the red tether cable.
Jacob
Unread 03-05-2007, 09:57
The usual answer is obvious: use a laptop computer with a built-in battery. The question seems odd enough that I figure I'm probably not understanding it. What are you using for a dashboard?
Unread 03-05-2007, 09:58
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
as jacob was saying hook up the tether between the OI and RC when you turn on the robot the OI should turn on. just make sure to take a few extra batteries. they die pretty fast. good luck with your fund raiser.
EDIT: i was not sure if you meant dashboard on the computer or OI.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
AKA: Jacob Komar
I think that he(?)'s referring to the OI. If this is for a demo, that's what it sounds like.
Jacob
Unread 03-05-2007, 10:09
You can power the OI from a robot battery. Measure the output from the wall-wart power supply to determine its polarity. Wire a similar plug to an Anderson battery connector, matching the polarity. If you're not comfortable exceeding the "spec" supply voltage, use six D-size alkaline cells in series, or a high-capacity 9.6v NiCd rechargable battery pack.
I've considered using cordless drill battery packs as a portable OI supply, with a built-in slot on the operator console to accept one. (The ones I've been toying with are many years old, from the days when they were used to power FRC robots, and don't last very long.)
Unread 03-05-2007, 10:12
If your problem is powering your operator controls, then a battery pack is all you need. You can find all the parts you need at Radio Shack.
Unread 03-05-2007, 10:40
Sorry, I meant the OI. Thanks for the help
Unread 03-05-2007, 10:59
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
That works, but a good 9.6v rechargeable will run longer. And you can still find all the parts at RadioShack.
Eric Haskins KC9JVH
Unread 03-05-2007, 11:41
would you set up the 9.6v rechargable in a similar fasshion as the battery pack that Mark mentioned?
Unread 03-05-2007, 11:52
I've also used the Vex 9.6v packs with a short connecting piece that has a standard RC battery connector on one end wired to the OI connector on the other.
Power to Dashboard cjelly Electrical 4 27-06-2006 21:08
Dashboard for .NET seanwitte Programming 8 16-02-2005 10:09
Dashboard for .NET seanwitte Control System 1 29-01-2005 03:50
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
Dashboard for Pocket PC James Crivellone Rules/Strategy 8 10-01-2002 12:18
