Go to Post Really let's not remove the best part of the games and that is the human interaction with the robots. Humans are much more adaptable and interesting when it come to problem solving. - Steve W [more]
Unread 03-05-2007, 19:13
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
trig
does anybody know the trigonometry code? is there a math.h file in mplab?
Unread 03-05-2007, 19:16
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: trig
im not sure but did you try
#inculde<math.h>
at the top
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 03-05-2007, 19:21
in between teams
AKA: Luke Van Oort
Re: trig
Yes, there is a math.h. However, use it with caution, the RC is notorious for bogging down on complex mathematics, especially floating point operations. A good workaround is the trig lookup tables in stored in the microcontroller's eeprom, which Kevin Watson has already written code to do. (linked to here)
Team 1219: 2009 - Mentor
Unread 07-05-2007, 13:13
tseres's Avatar
Re: trig
the only problem is that kevin's code only does sine and cosine. we need inverse tangent, though. any suggestions? and does anyone have the functions created to do this?
Unread 07-05-2007, 13:58
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: trig
there used to be some code floating around for it that was develop by a team a few years back to be able to do floating point math.....kinda.....ill see if i can find it again, or maybe some nice person will post a link
[EDIT] found it http://www.chiefdelphi.com/media/papers/1575 [/EDIT]
hope it helps....i don't like to mess with trig on this hardware, but this made life a little easier....
Unread 07-05-2007, 14:28
tseres's Avatar
Re: trig
thank you thank you thank you....thats EXACTLY whal i was looking for!!!!!!!!
Unread 07-05-2007, 16:15
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Re: trig
You can also approximation trig functions using a finite number of terms from the Taylor series.
For instance, arctan(x) is approximately equal to X - X^3/3 + X^5/5 - X^7/7
When -1<X<1
I'm not a coder, so I don't know what you’re trying to do, but from what I do understand about code, a Taylor series approximation should be fairly easy to implement.
Team 418 Purple Haze
http://www.lasarobotics.org/
Unread 07-05-2007, 16:39
in between teams
AKA: Luke Van Oort
Re: trig
When -1<X<1
Just to elaborate for those who haven't had second semester Calculus (BC Calc), a Taylor series is a mathematical construct that consists of a sequence of terms (often infinitely long), the sum of which approaches, know as converging at, a value equal to the value of the function used to generate the series. Taylor series are "centered" at a value and the points for which they converge to the correct number surround this value, in the above example, the series is centered at x=0 and the Taylor series converges from -1<x<1. Anyway, Taylor series allow you to use relatively simple polynomials to calculate rather difficult problems, like sin(.3245212432) to almost degree of accuracy that you desire, simply by varying the number of terms. This is actually how your calculator calculates trig functions, as it is rather hard to do straight up.
Trig Lookup Table michniewski Programming 6 23-02-2007 20:57
Trig problems revolution1737 Programming 8 19-02-2006 01:09
No Trig? The Lucas Programming 1 15-01-2004 04:07
Trig archiver 2001 4 23-06-2002 23:14
Inverse Trig K. Skontrianos Programming 6 13-03-2002 23:27
