Go to Post This is where a tenacious NEM comes in very handy. - Mark McLeod [more]
  #31   Spotlight this post!
Unread 29-04-2007, 09:14
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: Post URL to your autonomous mode
Originally Posted by D Collins View Post
The compilation video sounds like a great idea. Thanks for doing the work to put it together.
Here are a couple of videos showing 2046's autonomous on Curie. Our robot uses the camera to score on the middle spider leg under a light. We were 5 for 7 on Curie.
Curie Qualification #27 http://files.filefront.com//;7373893;;/
Compilation of 2046's Curie Auto http://files.filefront.com//;7373970;;/
Got it.
Doug Leppard
  #32   Spotlight this post!
Unread 29-04-2007, 09:26
Originally Posted by Kristian Calhoun View Post
Here is a autonomous compilation video that I recently made, showcasing our successful caps. In order, from the video's sequence, the matches are:
NJ Match 39 (This keeper actually didn't count, as it was supported by the stinger.
NJ Match 11
UTC Match 64 (One bot from each alliance capping, us on blue, 1124 on red.)
Galileo Match 22 (Nice close up shot.)
Galileo Match 82
Galileo Match 90* (1126 positions correctly, but knocks off their keeper as they back away. We cap ours on the same alliance.)
UTC Match 52**
NJ Finals 1*
NJ Finals 2***
Match 52 from Galileo, Match 52, and the NJ Finals are my favorites. (I'm still amazed at how we scored in match 52 after slamming into the rack and pulling up from beneath the spider.) As for our method, we used a single ultrasonic sensor to determine the proper distance from the base of the rack. During the matches at NJ, we used the CMUcam to align left/right towards the light, if it were in the view of the camera, and if not it would proceed to use the sonic sensor code. At UTC, we experienced camera troubles, and decided to just use the sonic sensors, and try our best to determine/guess where the spider leg would be after the rack had been moved. At championships, we solely used this method, and scored during 3 out of our 7 qualification matches.
The asterisks indicate my preference on which are the most entertaining to be used for the video, three stars being the highest.
Got it, great job.
Doug Leppard
  #33   Spotlight this post!
Unread 29-04-2007, 09:32
Originally Posted by Joe Ross View Post
330: http://www.thebluealliance.net/tbatv...07/ca_qm36.avi
We just dead reckoned using potentiometers on the wheel and arm.
We were 1/16 at LA, 2/18 at San Diego and 3/15 at the Championship.
Also, 48 pushing us into perfect scoring position: http://www.thebluealliance.net/tbatv...7/cur_f1m2.wmv
got it.
Doug Leppard
  #34   Spotlight this post!
Unread 30-04-2007, 18:38
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Not a real good shot of what happened, but here is 1425 scoring on the bounce in QF 2 in Las Vegas. Not our best working auto-mode, but our most unique.
http://www.thebluealliance.net/tbatv...p?matchid=3165
I could not get the SOAP url since the soap site seems to be down at the moment.
The next match is an example of how it was supposed to work - efficiently but boring.
http://www.thebluealliance.net/tbatv...p?matchid=3161
  #35   Spotlight this post!
Unread 01-05-2007, 18:05
Got it. I like boring, just get the job done. Most of ours are boring.
Doug Leppard
  #36   Spotlight this post!
Unread 03-05-2007, 14:30
The Lucas's Avatar
CaMOElot, it is a silly place
Team 365
Curie Q56 http://www.thebluealliance.net/tbatv...7/cur_qm56.wmv
This match is my favorite because 716 shakes the rack with its dead reckoning auto attempt but MOEzilla hits it anyway on a slightly offset spider. Also, with 4 teams attempting keepers there is a lot of movement.
We use the camera, gyro, wheel encoders and occasionally sonar and IR sensors. If I get some time I will writeup something about the decision making and step based nature of the code. Also I will try to lookup our stats later but I wanted to get a video to you in time.
Robot Inspector
  #37   Spotlight this post!
Unread 03-05-2007, 15:05
dtengineering's Avatar
AKA: Jason Brett
Here's our most entertaining auto:
http://www.thebluealliance.net/tbatv...hp?matchid=281
Jason
P.S. Thanks again to the Blue Alliance, Soap, and all the video editors for making this so easily available.
  #38   Spotlight this post!
Unread 03-05-2007, 15:31
Originally Posted by The Lucas View Post
Team 365
Got it. That was good. It will be used. You don't have to send more info at this point.
Doug Leppard
  #39   Spotlight this post!
Unread 03-05-2007, 15:35
Jason
That is classis! I love it. Problem is it says the video is not available for download. Bummer I would like to use it. Do you know of a downlaodable version and what team was it?
Doug Leppard
  #40   Spotlight this post!
Unread 05-05-2007, 22:20
JayZ's Avatar
JayZ JayZ is offline
FRC #0079 (Captain Krunch)
JayZ is on a distinguished road
here are a few videos of team 79's autonomous mode. they are all from atlanta on the Galileo field.
http://www.soap.circuitrunners.com/2...al/gal_052.wmv
http://www.soap.circuitrunners.com/2...al/gal_078.wmv
http://www.soap.circuitrunners.com/2...al/gal_101.wmv
we started by clamping the ringer and waiting until we found the light. we chose beforehand whether we would then wait 5 seconds extra for another team's autonomous to move out of the way. then we turned toward the light as we drove forward. once the camera told us we were close enough we quickly spun the wheels backwards for a short time to make us stop immediately. we moved the arm to a preset position based on a potentiometer, then let go of the keeper and backed up.
Originally Posted by FIRST '07 GDC
Woe be to ye who doth violate the Home Zone of thyne opponent. For thyne opponent's wedge may reach out and smyte thee, and ye shall be right out of luck.
Originally Posted by FIRST '09 GDC
We never let common sense stand in the way of convoluted logic.
  #41   Spotlight this post!
Unread 06-05-2007, 07:05
I always enjoy watching 79's auto mode. the flip over is really something to watch.
You are defintely in the video. I just finished this morning in collecting the videos. I have 31 robots at this point doing auto mode.
Doug Leppard
  #42   Spotlight this post!
Unread 06-05-2007, 09:17
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The two times our autonomous was successful were in the quarters at Buckeye. A couple of the best matches we had all year too.
http://www.soap.circuitrunners.com/2.../oh_qf4m2x.wmv
http://www.soap.circuitrunners.com/2.../oh_qf4m3x.wmv
  #43   Spotlight this post!
Unread 06-05-2007, 14:14
Fanatastic. I didn't have a video for you guys, I added the video to our list.
Doug Leppard
  #44   Spotlight this post!
Unread 19-05-2007, 17:51
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Team 1629 goes to the far side of the rack at PARCX
The clip below shows the auto mode that we never got to try at regionals.
In this match, 5 of the 6 robots had an autonomous mode. In this clip "Sticky" the Garrett Coalition (1629) bot makes a highspeed run to the far end of the field, sideswiping a blocking robot and then turns back to the rack and rings a keeper on the middle level.
A gyro is used to hold the heading in the straight run and initial turn, then the camera is used to get a range and bearing on the target.
YouTube here:
http://www.youtube.com/watch?v=D2kuUp9Rvw8
The hi-res clip is here:
http://www.gearsinc.org/images/1629_full_auto.wmv
The raw video is here:
http://www.gearsinc.org/images/1629_raw_fullauto.wmv
Phil.
Phil Malone
http://www.GEARSinc.org
  #45   Spotlight this post!
Unread 19-05-2007, 22:17
Re: Team 1629 goes to the far side of the rack at PARCX
YouTube here:
Phil.
that was great, soemthing we had planned but ran out of time, glad to see you do it.
Doug Leppard
Autonomous mode HellBoy Programming 4 07-02-2007 18:22
autonomous mode seanl Programming 6 31-01-2007 15:59
Is there a way to read your Team Colour during autonomous mode? Firestorm Programming 2 19-02-2005 18:57
Autonomous Mode Yellow Eyes Programming 2 18-02-2004 21:16
autonomous mode Stephanie Programming 2 25-01-2003 19:57
