Go to Post PS: Please use the default font for postings, it is so much easier to read. - DonRotolo [more]
Unread 06-05-2007, 01:12
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
254/968 Gearbox Assembly Time Study/Analysis
Many of you were curious about the "snap together construction" and “one minute assembly time" of this years gearboxes. In preparation for our senior project presentation and our final report, we conducted a time study and efficiency analysis of the gearbox assembly in line with some of our industrial and manufacturing engineering requirements for the project. The setup shown in the video was created to mimic a production environment, where parts and hardware are stored in replenishable bins, or on angled racks, feeding a new part in a specific orientation both aiding and speeding up the assembly of each finished gearbox. This is in no way a representation of how these were assembled in real life during the six-week build. This is to show how and why some of the design decisions were made in an effort to decrease assembly and dissasembly/maintenance times.
Here is the video: Gearbox Assembly
Our initial assembly times, prior to any right hand left hand part placement optimization gave us assembly times in the two to three minute range. After dozens of tests, optimizing the part placement and the assembly procedure, we eliminated many of the awkward hand swapping and extended part reach slowdowns. Our first few tests with an optimized parts placement layout gave us times in the high one minute range. After a long and slow learning curve, our first assembler was able to finish in one minute 20 seconds.
After further refinement of the layout and the assembly sequence, we were able to meet our estimated one minute assembly figure. Unfortunately, this only happened after nearly 50 previous efforts. While a continual decrease in time yielded a rather typical learning curve, the final one minute time is below what we have concluded to be 'optimal', being somewhere in the neighborhood of 130% efficient for a typical worker on an eight-hour shift.
This efficiency simply means that in normal production scenarios, the worker would not be assembling these one per minute. An average assembly time near 1:20 is a more reasonable expectation after our limited testing.
Many of you might say "he cheated" or "that's not very fast" but please remember, this study was done more as an example for what would be done in a real world production scenario. While it IS possible to be done faster, the ability for most people to maintain such a speed for a typical 8 hour workday is near impossible. Our original estimates of 1:00 had already taken into account some of the tasks that would be done prior to final assembly. Ex. bearings being pressed into plates. The setup could have been different, but we chose to make the assembly as comprehensive as we could, while eliminating the mundane and slow tasks such as bearing pressing.
Some of you may notice the lack of hardware. This is by design. The removal of all nuts from the gearboxes saved nearly two minutes of assembly, even while accounting for the additional time required to press in threaded inserts. The removal of keystock and keyways eliminated an additional one minute from assembly as well. While these things may increase the initial manufacturing time and costs, the savings in weight, increase in strength, and decreased assembly/disassembly/maintenance times was determined to be well worth it. The reduction of the total quantity of parts as well as the design of critical components such as the output shaft also allowed the assembly time to decrease and enable quicker and easier removal/tracking of parts for disassembly and maintenance. Spacers were removed or integrated into existing components when the weight savings difference was negligible.
Overall, this gearbox was designed to be as light as possible, with as few parts as required while being simple and quick to assemble and disassemble using only a handful of tools. We feel we have accomplished it well, but as always, there are improvements to be made.
While this is only the first of a few posts we plan on making with regards to the gearboxes, we would like to thank all of those who inspired us as high school students to pursue engineering who also sparked many of these ideas and created many solutions that we borrowed throughout our time in FIRST. Andy Baker, Paul Copioli, Joe Johnson, and Glenn Thoroughman to name a few... there are many more out there... but we wanted to recognize these guys specifically. It is important to create your own ideas and to continually improve existing ones, but more important than that, you must remember and acknowledge those whose footprints you follow in. These guys really helped us out over the years, both directly and indirectly... we thank them and all the others we haven't mentioned! We hope to one day be as good of engineers and role models as these folks are.
Please feel free to ask any questions, too!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 06-05-2007, 01:32
run the trap!!!
Team Role: Human Player
Re: 254/968 Gearbox Assembly Time Study/Analysis
Video isn't working. Just getting sound.
I'm kind of confused. Didn't it take you guys something like 500+ hrs. to machine all those custom aluminum gears? How did you bring it down to 1 minute!
-Philip J. Fry
Unread 06-05-2007, 01:34
Engineering Mentor
FRC #0254
Try using IE or right click and "save target as". You may also need the divx codec to play it. Let me know if thats the problem.
Notice that it is all about "assembly" and not manufacturing.
-Travis Covington
Unread 06-05-2007, 01:35
Brandon Holley's Avatar
Originally Posted by Travis Covington View Post
Try using IE.
Video worked for me....
very impressive travis...i love this gearbox
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 06-05-2007, 03:03
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
Even for someone who isn't on the assembly line this gearbox is beyond easy to put together. I remember taking it apart and putting it back together in 3 minutes maybe?
team4element
Unread 06-05-2007, 04:12
Joel J's Avatar
Joel J Joel J is offline
do you..
These are nice gearboxes. Loved the gearbox, loved the ramps. Quality.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 06-05-2007, 09:50
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
1 minute assembly not production
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 06-05-2007, 13:45
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I would like to thank all of those who inspired us as high school students to pursue engineering who also sparked many of these ideas ... These guys really helped us out over the years, both directly and indirectly... we thank them and all the others we haven't mentioned! We hope to one day be as good of engineers and role models as these folks are.
Travis -
Dont' worry, with work like this you are well on your way to being there.
-dave
Unread 08-05-2007, 13:40
jackie Ha's Avatar
jackie Ha jackie Ha is offline
Team President and Captain 05'-07'
AKA: Jacqueline Ha
FRC #0968 (Robotics Alliance of West Covina aka RAWC)
jackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to behold
Send a message via AIM to jackie Ha
That was fun. I never thought I could assemble an entire gearbox in a minute and twenty seconds. Good luck with your senior project. =P
If you can't be a good example, then be a horrible warning!!!
pic: 254/968 Transmission Travis Covington Extra Discussion 42 24-04-2007 16:25
pic: 968/254 Transmission Joe Ross Extra Discussion 4 03-04-2007 00:25
pic: 254 and 968 on Newton alphaone Extra Discussion 10 17-02-2007 08:28
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
Question for 254, 22, 968, 60, or 22 sanddrag Technical Discussion 1 13-01-2006 09:49
