Go to Post So my mom gave up most of the house to robotics.... - ElfMaster [more]
Unread 06-05-2007, 22:57
Re: Making a Waterfall
Float planning already? Or are you doing something else?
I'd suggest taking a box of, say, wood (material doesn't matter right now) and lining it with, say, a trash bag. Now, the trick is to get a flat flow, so try cutting a flat rectangle out near the top of one side. Fill it with water from above to the point where the water is flowing out from the rectangle. Hopefully, the water flowing out will be fairly flat, and the box angle can be adjusted for the flow you want.
All the flat waterfalls I've seen have had a flat lip at the top, just under the water. As long as nothing is in the way, it should stay flat. (And, if you are building this for a float, that includes in the way in case of sudden start or stop.)
Making Gears Joe_Widen Inventor 9 14-05-2006 18:41
making of a tutorial Nimmy 3D Animation and Competition 1 31-03-2006 11:47
Making an Animation Jimbo5051 3D Animation and Competition 4 31-01-2006 21:05
Button Making PureMachine4 Rumor Mill 58 16-04-2004 16:00
Making a Band archiver 2001 41 24-06-2002 04:11
