Go to Post If I was making this I would want to not have to use anything smaller than a 3/16" end mill, but 1/8" would be acceptable. Anything smaller and I'd tell the designer to go play in traffic. - Cory [more]
Unread 07-05-2007, 14:56
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
2 Speed Transmissions in the Future
Will 2 speed transmissions be used by more teams in the future? I don't know how many teams use them, but it seems like more and more are using them as time goes on.
Are they easy enough that rookie teams feel super confidant in them? I know it's not easy for some rookie teams put together a dominate robot, even thought they can and do, and I don't even know if some rookie teams have used 2 speed transmissions.
Can FIRST Design, or have someone design, a 2 speed transmission that is just as reliable as the KOP transmissions from 05' and 06'? And will they become affordable enough to be in the Kit Of Parts?
I would like to get the FIRST communities thought's on these questions.
Unread 07-05-2007, 14:59
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Re: 2 Speed Transmissions in the Future
Anyone that has the dough can buy an AM shifter. reliable, good ratios, and not too heavy. Thats one of the more common 2 speeds out there. Between that and the Dewalt, transmissions arent too hard to make.
BUilding your own is where things get tough.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 07-05-2007, 15:04
AdamHeard's Avatar
Lead Mentor
The use of shifting transmissions will increase as long as there is a benefit. In the recent era of first, more often than not they are useful.
I don't think they should be in the KOP however. Giving rookie teams a fully functioning gearbox is pretty generous already.
Unread 07-05-2007, 15:07
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Too expensive to put them in the KOP. an extra $660 per kit, with 1200 teams would be nearly $800k that would have to come from somewhere.
Sure you could lower costs, but not enough to make it financially viable.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-05-2007, 15:49
Billfred's Avatar
Billfred Billfred is offline
They're becoming more common in my estimation, and I pin a lot of that on AndyMark. Just as the Kitbot has allowed for everyone to get a functioning drive system, the AM Shifter has allowed for anyone with $660 to go two-speed. Even as they get more common on the field, more teams are now able to get up-close and personal with a design known to handle almost anything FRC can throw at it and draw some ideas.
AndyMarks: Absolutely. If you can assemble the Kitbot, you can get the AndyMarks going.
Custom designs: That depends. If you've got mentors that can help you with the design (or, even better, provide a baseline setup to help get moving), I'd say it's within reach. But if your team hasn't ever seen an FRC robot before, I wouldn't touch it with a ten-foot pole.
Someone has designed a two-speed that's just as reliable (in my experience) as the Copioli kit transmissions, and even taken it to market. Still, I see no way on earth that the price difference between a BaneBots (or even a 2005 gearbox) could be made up.
However, it would be interesting to see someone come up with a solution that uses components from the kit gearbox. (The older transmissions would work better for this than the BaneBots, obviously.) I suspect such a design, if it could be done and brought to market, could swing a more attractive price than the current magic number ($660 for an average robot). This, in turn, draws in the teams whose reservation price (marketing-speak for the most they're willing to pay) is at some lower number--a team might not be willing to pay $330 a gearbox, but they may be willing to pay $250 or $275. The difference buys a lot of pizza.
Furthermore, if these new BYOG (Bring Your Own Gears) shifters stuck, it might move the reference price (which is used to judge the acceptability of a price in the mind of a consumer) lower altogether. Suddenly, the barriers to going two-speed shift (pardon the pun) from technical and financial to the need for it in the game, weight, and personal preference.
(This, ladies and gentlemen, is what you get for having marketing courses as half of your course load in a year.)
Unread 07-05-2007, 15:52
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
So are you saying that team's wouldn't agree upon adding $500 to the reg. fee to be able to have durable (not BB!) trans in the kits from years to come?
I would figure many teams would jump to it if all they had to do was pay an extra $500 to the reg. fee to get those in the kits.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 07-05-2007, 16:08
Before 2005, there were shifting transmissions in the KOP. Bosch drill trannies, which interfaced with the Bosch drill motor found in those kits. Anyone remember those? (Oh, and Adam--you should know about the "fully functioning" gearboxes in the 2007 kit--or were those KOP?)
There are 2-speeds out there that aren't AM, but they might not work with what we've got available. If 254/968 marketed their gearbox, especially if it was less than the AM 2-speed, I'd probably take a close look at it. Now, that still won't compare to having a 2-speed in the KOP, but I'd rather see a team look in the box, say, "this is not what we need," and then go about modifying the kit gearbox or designing a new one or otherwise thinking outside the (kit) box to get what they want.
Unread 07-05-2007, 16:10
Cory's Avatar
AKA: Cory McBride
No, they wouldn't.
$500 is a very significant amount of money for a lot of FIRST teams. More than many have available to build their entire robot with.
Any increase in price would not be well received by the FIRST community, even if it is "only" $500.
In addition, there's no reason that a low cost, reliable alternative to the banebots transmissions can't be included in the kit.
2001-2004: Team 100
Unread 07-05-2007, 16:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I doubt it, especially if they are paying $500 for an added feature (2-speed) that they might not even want to use (or use at all if it is pneumatically actuated).
$6000 is plenty, and even a semi-reliable transmission such as Banebots is much much better than what was used to be provided.
Unread 07-05-2007, 16:20
Brandon Holley's Avatar
I wouldnt want to pay any extra money for a kit where im not going to use the extra 500 dollars in components.
Until a robot NEEDS to shift to function in a game, i see no need to include a 2 speed tranny in the KOP.
If you have extra cash go buy some AMs or some dewalts...
I can say with a lot of confidence however, that most FIRST teams can design a 2 speed transmission themselves, and save some money....you have all the time in the world in the offseason... (OHH LOOK WHAT TIME IT IS...)
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 07-05-2007, 17:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think the kit of parts should include a silver platter as well.
</sarcasm>
Unread 07-05-2007, 17:13
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
No, they wouldn't.
I would think that FIRST could get with some company to manufacture parts for a 2 speed transmission so that the total cost of each transmission is less than $50 each. Our 2005 and 2006 2 speed transmissions were custom made by us and they were very reliable, and I would say that the materials in it did not go over $30 per transmission.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 07-05-2007, 17:37
Cory's Avatar
AKA: Cory McBride
There's no possible way, be it by buying gearstock, or individual gears that the cost of materials will be less than $30 per transmission. I wouldn't see any possible way for the material to be less than even $75-100 per side.
The Banebots transmissions hover around $50, and they have very poor build quality. It simply wouldn't be possible to pay for materials, and labor to machine all the parts required to make a two speed transmission.
2001-2004: Team 100
Unread 07-05-2007, 20:13
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
I think that if FIRST keeps pumping out games with the same relatively flat field with maximum of 30? inclines to climb, you will see more and more 2 speeds. There just isn't a challenge for teams to design anything besides a basic 4"-8" diameter, 4 or 6 wheel drive train. Its related to the arms race thread, but on a broader scale. Most teams wont try to make a V6 or anything like that, but with all the previous designs out there, a 2 speed isn't that much of a stretch for any semi-experienced team.
And there are teams out there that have almost reached perfection as far as 2 speeds go. 254/968 has the most elegant and thought out drive train I have ever seen. And it helps that they have had at least since 2004 to work out their design. I'm not quite sure if you can get any better than a 1.4 pound 2 speed gearbox (great job Travis btw) and I would doubt their entire drive train came out to be over 35 pounds. Thats 85 pounds to do whatever else you want to do with the robot! Being the one who is always working on arms/manipulators, it would be nice to be able to make something without having to worry if the drive train is gonna take up all of the robots weight.
In short, yes, as long as games continue to have fairly repetitive field layouts, 2 speed will become better and popular-er (is that a word? )
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 07-05-2007, 21:56
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Shifting Transmissions are somewhat overhyped. We were very competitive this year and didn't use them. 2006's game seem to be wide open and we used AM shifters and got good use from them. You just got to look at the game to see if it's worth your investment of time and money. If they release another game like 2004 First frenzy, I suspect most experienced teams would invest time and resources to other robot attributes.
This seems to be a thread twice a year on average.
Are two speed transmissions worth it? thefro526 Technical Discussion 43 19-04-2007 21:16
pic: 1126 4-Speed Transmissions '07 edition jagman2882 Robot Showcase 18 16-02-2007 00:06
AndyMark 2-speed transmissions gabrielse Kit & Additional Hardware 3 08-01-2007 11:32
New Ryobi 3-speed drill transmissions! artdutra04 Technical Discussion 5 23-04-2006 19:48
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
