Go to Post If you need more complicated control... make it more complicated yourself. ;) - Ryan M. [more]
View Poll Results: Do you think that FIRST will put the BaneBot tranny in the KOP for the 08 season?
Yes, and they'll make it better. 76 66.09%
No, it was a bad idea, and they'll never go back. 32 27.83%
Other (please specify below) 7 6.09%
Voters: 115. You may not vote on this poll
Unread 07-05-2007, 18:12
CraigHickman
Posts: n/a
The Future of FIRST: BaneBots?
I've been doing a little bit of planning. Assuming that FIRST worked with BaneBots to fix the issues with the transmissions this year, do you think that they will bring the BaneBot transmissions back into the kit for the 08 season?
Unread 07-05-2007, 18:28
in between teams
AKA: Luke Van Oort
Re: The Future of FIRST: BaneBots?
I think they'll probably stay with the BaneBots, but an improved version, for economics reasons. But, it seems to me that if BaneBots took some ideas from Copioli's transmission and the AM 1 speed and just made a gearbox with punched side plates and 1.25 module spur gears, they could probably build a much much better transmission for not huge sum more.
Team 1219: 2009 - Mentor
Unread 07-05-2007, 18:37
I think they will use whatever transmission is the cheapest, unless the contract for the 07 KOP gearbox lasted more than 1 year.
Unread 07-05-2007, 18:49
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I fear that this is the truth, but I hope that FIRST will heed the words of Dr. Joe with respect to the correlation between a robust drivetrain and an inspirational season. The benefit to the students from something moderately more expensive, like the single-speed AM, may very well far outweigh the cost.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 07-05-2007, 19:23
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
Our team thought the banebots were great. We were careful about supporting them and we only drove one motor with each transmission, but it meant that we had a nearly finished, holonomic chassis by week 3, which is something that we've never done before.
Unread 07-05-2007, 19:34
Billfred's Avatar
Billfred Billfred is offline
I think they'll test the contenders first (and this time, give 'em hell), then use the cheapest that survives.
Unread 07-05-2007, 19:35
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I picked "Other"
Yes
Will they make it better?
Aside from the plate issue, unlikely.
So basically my answer to the poll is:
Yes they will bring it back, but it was, and still is, a bad idea.
From our experience with the BaneBots motor and tranny I can say this much about it... Don't use it for anything that requires a lot of power unless you're a pyro. We tryed using it to power our manipulator (which we never did get to put on... <_<) and it nearly burned the place down!
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 07-05-2007, 19:51
REVving up for a new season
FRC #2848 (All-sparks)
I don't put much faith in their testing processes based on this year's results....
How about the smart thing gets done and the AM single speed goes in the kit.
Although unfortunately I feel that the Banebots will be back.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 07-05-2007, 20:11
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
I would like them to make these gearboxes available to teams that want them, but optional, so that it cuts cost for those who don't use these gearboxes, and don't want them piling up in their workspace or possible projectiles for freshmen... It would probably only knock off $100 at the most off the registration and kop. I wonder what the price cut is for buying these gearboxes in uberbulk...
We used the gearboxes, and although they did get the job done.., it would have been easier to just fabricate our own gearboxes, less problems/fixings, but stuff happened.
Remaking Paul's gearbox, and having it be built with 3/16" or 1/4" aluminum 6061 plates and having a variety of mounting holes so you can mount it to almost any chassis doesn't seem like it should be too much to ask for.
Unread 07-05-2007, 20:29
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
A busted gearbox is a showstopper. I can't think of many things worse than a broken gearbox in competition. I bit my nails all season and it turned out okay, but I had some steel plate and a waterjet to make a dozen spares (although we never needed them). As a rookie team pulling parts out of red and blue boxes for the first time, I would want something that I can trust to outlast the rest of the robot even if it's not properly fixtured. I'm not sure if I'm at the level of comfort with the BaneBots transmissions just yet.
That being said, we ran four BaneBots transmissions of three different sizes this year, two with hardened carriers, and all survived. They fit in tight spots, are easy to mount, very light, inexpensive, and they look cool. I'm already picturing them on one of our offseason projects. With a bunch of gear ratios to choose from, they will still be a valuable resource for FIRST teams, I think, whether or not the 56mm winds up in the kit next year.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 08-05-2007, 01:00
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
The only complaint about the 56mm transmissions is that they have not been battle tested.
Banebots as a company sells stuff primarily targetted to combat robotics, and their reputation is built on well built components that can survive severe abuse, more so than what we ever experience in FIRST. However, the 56mm never saw active battlebot duty as their other products, and I have to fault them for not having tested the transmissions for robotic combat.
My suggestion to Banebots is to hand over their transmission designs to real battlebot builders and see what they have to say. If it can survive that, then it can survive FIRST. If that happens then I will gladly welcome Banebots back to the Kit of Parts for 2008.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 08-05-2007, 01:38
dtengineering's Avatar
AKA: Jason Brett
I would be happy to see the Banebots back next year.
I am sure if you search for my build season posts on the topic you will see that our team suffered probably as much frustration with these transmissions as anyone... but the more I took them apart and put them back together the more I came to appreciate the sturdy and simple design. You can bet that Banebots will have the tolerance and materials issues worked out for next year. In fact, they already have the materials issues worked out.
Given the way Banebots took responsibility for their product, and at no small expense gave teams replacement carrier plates whether they needed them or not, I think they deserve our respect as a quality vendor who can be counted on to put forward a quality product next year.
And did I mention how nicely their encoders mount onto the axle shaft and how well they work? That is a factor in favour of the BB's that often goes unmentioned.
Jason
P.S. The suitability of the BB for direct drive is one of the true strengths of the product over some of the competitors. Direct drive directly increases overall drive system reliability by eliminating what is often the "Weak Link", the chain coming off the sprockets. From that point of view a direct drive BB tranny has the potential to create the most reliable rookie (or veteran...) drivetrain EVER in the KOP.
Unread 08-05-2007, 07:54
Gdeaver Gdeaver is offline
FRC #1640
If First continues with the cim motors and the intention of using 2 motors to a trans and a KOP 4 wheel drive set up, then I just hope that they will allow us to use the AM trans that we invested in this year. In my opinion for the Banes 56 with 2 cims to be a contender several other design issues need to be addressed. If these changes are made the cost of manufacturing will go up. I hope First gets a quote from AM for their trans.
Unread 08-05-2007, 08:20
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
This would be a good plan if FIRST has the manpower and resources to test them. I don't know whether they are in such a position, but assuming they are, how should FIRST test them? Maybe this person will take it on.
I think you hit the nail on the head here. While BB's did have their own problems, they probably improved overall drive system reliability for many teams.
Pete Kieselbach
Unread 08-05-2007, 08:35
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
I think FIRST will use whatever gets donated to them, whether they are good for the application at hand, or not. See Rockwell Terminal Blocks...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
FIRST becoming more critical in the future? thegathering Chit-Chat 8 22-09-2006 00:20
PreRookies, Mentoring and the future of FIRST Wayne C. General Forum 10 12-02-2006 02:02
the future of FIRST....i think? archiver 2001 13 24-06-2002 00:02
Will IT influence the future of FIRST? patrickrd Dean Kamen's Inventions 11 04-12-2001 01:12
