Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 07-05-2007, 22:10
run the trap!!!
Team Role: Human Player
Re: 2 Speed Transmissions in the Future
The assumption here also seems to be that tank-drive wheeled robots are the future of FIRST.
Omni and meccanum are barely controllable in low gear. Swerve drives are complex enough without the addition of multiple speeds. Track-drives have a tendency to throw belts at high speeds...
Not that these drive systems are incompatible with 2-speeds, its just that most teams are unlikely to build them.
There are other-ways to improve drivetrian usefulness then to add another gear...
-Philip J. Fry
Are two speed transmissions worth it? thefro526 Technical Discussion 43 19-04-2007 21:16
pic: 1126 4-Speed Transmissions '07 edition jagman2882 Robot Showcase 18 16-02-2007 00:06
AndyMark 2-speed transmissions gabrielse Kit & Additional Hardware 3 08-01-2007 11:32
New Ryobi 3-speed drill transmissions! artdutra04 Technical Discussion 5 23-04-2006 19:48
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
