Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 08-05-2007, 09:01
Re: 2 Speed Transmissions in the Future
Originally Posted by Gabe View Post
...the 2004 challenge didn't really seem to favor multi-speed transmissions because on top of the platforms there was no need for the high speed, with very little room to maneuver. If there is any serious obstacle the driver must slow down (except for the few who try to fly). The more obstacles, the fewer opportunities there are for the driver to use the fast speed...
One of my favorite tools for out-of-the-box thinking is to turn things around the other direction. In this case, you seem to be implying that the purpose of a second speed is to go faster. But it's just as reasonable to have a "normal" driving speed plus a second slow speed, used for extra torque when needed. Instead of a medium-speed robot that can switch into a higher gear to zip across the field quickly, consider a medium-speed robot that can switch into a lower gear to hold its ground or push others out of its way.
If the playing field is open, high speed tends to be an advantage. If the field is congested, pushing power tends to be an advantage. Both situations are well served by a shifting transmission.
Are two speed transmissions worth it? thefro526 Technical Discussion 43 19-04-2007 21:16
pic: 1126 4-Speed Transmissions '07 edition jagman2882 Robot Showcase 18 16-02-2007 00:06
AndyMark 2-speed transmissions gabrielse Kit & Additional Hardware 3 08-01-2007 11:32
New Ryobi 3-speed drill transmissions! artdutra04 Technical Discussion 5 23-04-2006 19:48
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
