Re: Mapping FIRST Teams
Could you add a table for dormant or extinct teams? I think that could be interesting historical information to see mapped out.
Added. Good idea!
I found this old thread from 05 if you want to compare the maps....
http://www.chiefdelphi.com/forums/sh...745#post387745 |
You're planning to make a global map of FIRST teams, right? If so, when are we expecting to see it?
Thanks to everyone who has added teams!! I challenge everyone else to add your team plus a couple teams in your area. |
Fine by me.
#7
Someone should make a kml file for google earth that uses this table to plot the location of all the teams
#9
Hello...
1172 should be from Richmond. The First site lists teams from Va. (under "what teams are from this state "in the "whats going on in my area " link)and they are listed as from Richmond. |
#10
Connecticut team map at www.ctfirst.org/map.htm
#11
<bump>
Has anyone build a KML network link to the FIRSTwiki table? http://wiki.chiefdelphi.com/index.php/Team_Info If not, I have a weekend project... -Pete |
#12
where do you enter your team information?
can i enter FVC/FTC teams as well? |
#14
http://bbs.keyhole.com/ubb/showflat....n//page/0/vc/1 (sourced from the Portland and Seattle websites) -Pete |
#15
I like the map idea.
May I suggest modelling after or gaining ideas from this map. http://www.flippinsweetdude.com/maps/index.php ...although perhaps while implementing some way to update every season from FIRST's team pages. That way teams would be removed if they became inactive or disbanded. I like the above link, because it has little icons. Some people wanted a vex map too. If you use some sort of icon system in yours, then you could differentiate between FRC and vex teams. |
| Mapping VEX I/O to FRC code | Doug Leppard | Programming | 3 | 14-05-2006 06:45 |
| Change joystick to pwm mapping | Joe Lewis | Programming | 3 | 30-03-2005 19:27 |
| Concept Mapping | Eugenia Gabrielov | Chairman's Award | 1 | 30-01-2005 17:28 |
| Default mapping relay questions | Jared Stofflett | Programming | 1 | 25-02-2004 19:06 |
| Mapping Buttons to PWMs | actorindp | Programming | 9 | 10-02-2004 11:11 |
