Go to Post I think this thread just won "ChiefDelphi is terrible Bingo". - Karthik [more]
Unread 09-05-2007, 23:47
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Picking up Cigarette Butts?
Does anyone have any ideas on how to pick up cigarette butts via a robotic mechanism?
I'm designing a robot that will pick up trash from ditches and what not... a huge problem is the cigarette butts on the side of the road among rocks. I've developed a way to pick up other trash such as pop cans, paper/plastic bags, and flag all other objects that would not be able to be lifted.
Team 648 spends several days cleaning up Quad City roadsides and other areas, so I figured it would be a nice way to attract more attention to FIRST and engineering if people saw students picking up trash alongside a robot.
I'm going to start Vex prototyping it tomorrow and then hopefully have a fully built robot by the time we do the X-Stream Cleanup in August.
Thanks in advance for any input.
Jeremiah
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 09-05-2007, 23:49
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Picking up Cigarette Butts?
The only thing I can think of is the fact that cigarette buds are probably lighter than rocks, so you could try some sort of vacuum. You may still need to use a filter of some sort though.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 09-05-2007, 23:57
CraigHickman
Posts: n/a
I'm thinking a very low force spring set attached to some needles, so the needles will spear the cigarette butts, but leave everything else (rocks and so on) on the ground.
Either that or a vacuum...
Unread 10-05-2007, 00:00
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Would a rake work?
Unread 10-05-2007, 00:03
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
How about using a vacuum and/or rake to pick up EVERYthing on the ground the size of a cigarette butt or smaller (limit the size of the intake on the vacuum and/or make the width between rake blades the proper size) , and spitting it out into a chamber with some kind of screen mesh. Using gravity, stuff smaller than cigarette butts would fall through, leaving the butts.
Seems complicated... kind of like a typical FIRST robot
Jacob
Unread 10-05-2007, 00:19
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If the cigarette butts are among small gravel, then a vacuum might not be the best idea, unless you want your robot's new nickname to become "ol' Clunky".
But if they are among anything larger (at least an inch or two across) rocks, and the vacuum isn't super powerful, then you should be fine. Vacuums do have the advantage of being able to suck up multiple ones at once, so they do present a nice solution. I'd do some testing first, though. Go to a local car wash* to one of the coin-op vacuum cleaners, and try sucking up cigarette butts from around the machine. (Alternately, you could try using the air intake on a leaf blower.) If it works well, then go for it and put it on your robot.
* An industrial strength vacuum cleaner or a leaf blower would probably be better handled to cope with rocks than your typical central vac or Dyson, so better to test it out with those.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-05-2007, 07:05
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I like Craig's idea of using needles. You could make the needles come through a sliding piece of sheet metal. The sheet metal would slide down the needles to clean them of the offending butts
Or you could use something like the R/C airplane Woodpecker. It consists of a rotating barrel with very small, sharp points of metal. It could roll along the ground and pick up the butts. Than you could devise a way to knock off the butts from the points.
E-mail me and I will send you a picture of the Woodpecker.
Or you could get a bunch of Freshman to pick them up
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 10-05-2007, 07:50
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Flamethrower.
Cigarettes are flammable, rocks are not.
Don't overcomplicate things.
OR
Have a steady stream of water coming out the front of the robot. Trash tends to float; simply have a sieve at the bottom of the hill for all the trash to float into and the water to pass through.
(same effect can be reached with a leaf blower. 30 bonus points if you can blow the trash up 12 inches in the air.)
Hi!
Unread 10-05-2007, 09:48
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Originally Posted by boiler View Post
Flamethrower.
Best idea yet!
The vacuum may work, but the butts are sometimes embedded into the ground. The needles might be the next best option.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 10-05-2007, 10:12
Go VOLS!!
AKA: Budda648
no team (QC Elite)
I was thinking exactly along the line of what Wayne had mentioned. The needles through the metal would be fairly simple.
The flamethrower would be ideal... in a desert. I like it, but I don't want to start a wildfire, that would be counterproductive.
Do The Tyler!
Unread 10-05-2007, 13:46
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
go along the lines of a street sweeper. Have a mabuchi motor spin a brush and then have a collector where the butts are deposited.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 10-05-2007, 17:06
Budda,
Vacuum, the little buggers are pretty light.
Unread 10-05-2007, 21:58
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
i was illiterate just thinking about this problem right before i got on cd to night i
think a curved needleis the way to go
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 10-05-2007, 22:42
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Budda,
The only thing I'm worried about with those suggestions is picking/kicking up the dust. If I were to do this, how would I resolve that issue?
The pickup system has also got to withstand multiple terrains, which poses the most problems with the street sweeper.
Do The Tyler!
Unread 11-05-2007, 07:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
How about.....
...you build a robot that promotes the cessation of smoking in your community?
Then as people start to quit as a result of your creation, the cigarette butts on the road will gradually fade away.
Perhaps a bit too altruistic (and unrealistic), but it's a nice thought.
microcontroller picking up noise? sciguy125 Electrical 24 18-09-2007 22:14
Picking alliances geowasp General Forum 37 03-04-2007 20:57
Picking Up a Robot phittman General Forum 14 15-02-2007 14:53
Alliance picking Shu Song General Forum 44 13-04-2005 19:29
Picking Drivers? ERock(NJ) Team Organization 51 13-10-2004 20:45
