Go to Post A sign of character is the ability to move on and make the best of what you have, even if you feel you were completely wronged. - Cory [more]
Unread 09-05-2007, 17:45
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Removable Electronics
Originally Posted by copperhead47 View Post
haveyou experimented with other clear materials other than polycarb? bnecause to my knowledge, poly carb used in liberal amounts is some what heavy although i could be wrong
The 2007 box weighed about 10 lb.s, which isn't terribly bad compared to many other control board set-ups I have seen. Due to the fact that you have to see the lights on the victors, spikes, and RC, we needed a clear substance to make the control box out of, which is why we chose polycarb.
Unread 09-05-2007, 17:52
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
thats pretty cool....i'll have to remember that for next year.
*edit*
just curious (this should probably be in programming, but, meh) how do you get power to the large fan? does it just hook up to a PWM output on the RC? or do you have to splice it and hook it up to the battery?
Unread 10-05-2007, 07:26
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
For a lightweight alternative to heavy polycarbonate, you can always take thin lexan (1/16 - 1/8" depending on #lbs you want to support) and bend it in a pressbrake, no heating necessary if you go slow, just make sure you leave the backing on the lexan till your done bending so it remains optically pure.
If you place your bends right, we were able to mount 2nd level of our control system (4 victors, 4 solenoids, robot controller, three air tanks, allen bradly blinker assembly, 4 spikes) on a single piece of 1/16" lexan. Don't know if the brand matters but we used Markolon.
Any questions, just give me a holler.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 10-05-2007, 08:00
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Just connect it to a 20 amp breaker. I don't think a spike is necessary. And besides, the fans on the victors are wired in this way.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 10-05-2007, 17:57
tseres's Avatar
sorry...i worded my qustion wrong....i didnt mean the vidcot muffin fans...i meant the big fan....180? or something like that. the one that made the "wind tunnel" effect..
Unread 10-05-2007, 18:27
in between teams
AKA: Luke Van Oort
The answer is still the same, unless you want to turn it on/off. If you did, you could wire it to a spike.
Team 1219: 2009 - Mentor
Unread 10-05-2007, 18:34
tseres's Avatar
ok....thanks...i kinda wanna do that kind of idea for the electronics box next year. i like how it looks and how it works. it would have solved a lot of problems this year of, like, 6 ppl working on the robot at a time..
Unread 16-05-2007, 19:29
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
This latest picture, posted by Pavan (thx much), shows off the globbable quick disconnect connectors quite well:
http://www.chiefdelphi.com/media/photos/28626
You can see that they have them lumped together into groups of fours....
Jacob
Unread 16-05-2007, 21:07
tseres's Avatar
Jacob
WOW....just.....wow....man, i gotta do that next year.. do you know if they had any cooling problems with everything that close together? and do the wires going to the victors connected with o-connectors? or do they have, like, heat-shrink or something similar on them?
Unread 17-05-2007, 15:58
jsmith234 jsmith234 is offline
Jared Smith
FRC #0234 (Cyberblue)
Team Role: Electrical
jsmith234 is an unknown quantity at this point
Send a message via AIM to jsmith234
Where are those quick disconnect connectors available to purchase?...I would love to add those to our board design this next season.
Cyber Blue - Team 234
2007 BMR Chairmans Awards & Regional Champions
Entrepreneurship Award, Website Award
2007 Long Island Regional Champions,
Industrial Design Award
Unread 17-05-2007, 16:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
As mentioned earlier, they are Anderson Power Pole connectors. One vendor is Powerwerx (http://www.powerwerx.com/Default.asp).
Unread 21-01-2008, 18:38
Ricki E. Ricki E. is offline
Ricki
AKA: Purdue FIRST College Mentor
FRC #1646 (Precision Guessworks)
Ricki E. will become famous soon enough
Send a message via AIM to Ricki E. Send a message via Yahoo to Ricki E.
Originally Posted by Lil' Lavery View Post
116 has used our modular, removable "control box" on 4 different bots at 11 total competitions (developed summer 2004), with only one issue (during a practice match in Peachtree 2006, and it was an issue common to any electrical system). I don't think that 116 will be switching away from the design anytime soon. 2005 Control Box thread
2007 version (before wire runs were cleaned)
How much does that approximately weight?
Team 4 Element- "Igniting the Flames of Passion"
Unread 21-01-2008, 18:54
DonRotolo's Avatar
Back to humble
FRC #0832
The 2007 box weighed about 10 lbs
Don
Unread 22-01-2008, 02:29
eeeeweeezeee's Avatar
eeeeweeezeee eeeeweeezeee is offline
menace to public safety
FRC #0114
eeeeweeezeee will become famous soon enough
Send a message via AIM to eeeeweeezeee
My team has done the polycarbonate enclosure thing before. that pic from 116 looks a lot like the "brain box" my ream worked on about the same time, but we never adopted the design. ours was almost the exact same but with 2 120mm fans and it was translucent blue plastic. ours didn't work out in the end though, when we forgot to take into account wiring. that ever so important flexible copper that links it all together is just a little more bulky than most people realize, and we never did try making a new box with an additional 1" on all directions.
we currently Velcro the parts to sheet metal attached to the frame covered with a Lexan plate that removes with several screws, and also has some hinged doors for frequently accessed parts like the programming port. this plastic sheet that covers the robot frame is also a convenient place for sponsor stickers to cover where there isn't anything interesting to look at through the clear plastic.
EEEEWEEEZEEE
was here
Robot electronics geo Chit-Chat 1 17-02-2007 22:42
Electronics visible? WhiteTiger Electrical 21 16-02-2005 23:50
Electronics alarms Sam Oldak Chit-Chat 0 03-05-2004 17:02
Covering Electronics shyra1353 Rules/Strategy 6 24-02-2004 22:23
mounting electronics nwagers Electrical 10 15-02-2002 13:09
