Re: problem with speed controller
Also check to make sure your battery isnt so far gone your RC is resetting... or that you used too light a guage of wiring...
If your radio is located near the motor or is using out-of-date firmware, it could be resetting due to magnetic flux from the motor. Is your gear ratio large enough? Perhaps the motor is encountering too much torque. Gimme a yell if any of that works or doesnt... -q |
| Problem with the 2005 controller | Guy_E | Programming | 10 | 18-12-2006 01:38 |
| Speed controller Problem fixer upper | Andrew Rudolph | Control System | 2 | 21-02-2005 08:22 |
| Speed controller Problem fixer upper | Andrew Rudolph | Electrical | 2 | 21-02-2005 08:22 |
| trouble with pwm speed controller | jakk | Control System | 4 | 10-01-2005 02:51 |
| trouble with pwm speed controller | jakk | Electrical | 4 | 10-01-2005 02:51 |
