Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 11-05-2007, 12:29
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Picking up Cigarette Butts?
Im thinking the needles might have issues on none flat ground. Obviuosly there are ways around this but a vacuum seems to be the easier method. I would prototype them both first and see which works better before I made any full scale models or final decisions.
Unread 11-05-2007, 14:18
If you have a high poower blower and a strainer, the light stuff would be sucked up and the strainer would hold the butts and deposit everything else out the back. It might be a bit dusty but it could get the job done.
Unread 11-05-2007, 14:35
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
I thought of this just a moment ago and this may be the best solution. If I were to periodically move a collection system under the vacuum and power it down, the butts and smaller debris would fall down into the sack. Thanks Al.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 11-05-2007, 16:15
mizitchell's Avatar
mizitchell mizitchell is offline
AKA: Mitch
FRC #2075 (Enigma)
mizitchell is on a distinguished road
try a steam roller-esk thing covered with needles and on the topside have a rake that fits between the rows of spikes to get the cigarette butts of the spikes
i was thinking that you might have issues with fine dust or sand if you use a vaccum
Unread 11-05-2007, 19:19
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I like this steamroller idea. I could totally see this working... but you don't want it going haywire and start running over cars with sharp spikes....
And I love flamethrower idea
Jacob
Unread 11-05-2007, 21:32
mizitchell's Avatar
AKA: Mitch
FRC #2075 (Enigma)
you could always work on your gratious professionalism by trying to talk your way out of it
Unread 11-05-2007, 23:01
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Talk my way out of what?
The steam roller idea won't work because it won't be able to go on all terrains, it's mainly a flatland thing.
Do The Tyler!
Unread 12-05-2007, 00:33
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
I would go the vacuum route. What you could do is have a small vacuum on the end of an arm so you can use it on any terrain. Dust would be kicked up but would be sucked in by the vacuum, and you could use filters to try to catch or leave behind certain materials. You would have the vacuum first run through a large filter that catches large rocks and such, and have this filter slanted to the side with openings so that all the rocks and such fall back onto the road(or if you want to vacuum up large objects for some reason you can simply close these vents off) and then have everything else pass on to the next level. The next level would be small enough to catch the cigarette butts and but be large enough to let dust pass through. After the dust filter you have an opening either right under or behind the robot and have dust simply fall through this opening onto the ground so it doesn't weigh the robot down.
Seems good in concept. However that tends to mean little when you finally build something so I would suggest exploring a couple of the ideas in this thread and prototype them.
Last edited by Herodotus : 12-05-2007 at 00:36. Reason: Horrible grammar and typos.
Unread 12-05-2007, 12:12
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
wait what is the harshest terrain conditions that you will be operating on? any sand? gravel?
i think before you start to design you should go around and find out exactly what you will be designing your robot for.
just my two cents, vivek
microcontroller picking up noise? sciguy125 Electrical 24 18-09-2007 22:14
Picking alliances geowasp General Forum 37 03-04-2007 20:57
Picking Up a Robot phittman General Forum 14 15-02-2007 14:53
Alliance picking Shu Song General Forum 44 13-04-2005 19:29
Picking Drivers? ERock(NJ) Team Organization 51 13-10-2004 20:45
