Go to Post [Hints] usually come out right before Christmas. Be patient, and go do something else with your life while you still have time! - Libby K [more]
Unread 09-05-2007, 15:00
Pnakovich's Avatar
Pnakovich Pnakovich is offline
AKA: Paul Pnakovich
FRC #0612 (Chantilly Robotics)
Pnakovich has a spectacular aura aboutPnakovich has a spectacular aura about
Send a message via AIM to Pnakovich
2006 Kit of Part Transmission
Does anybody happen to have a copy of the 2006 Kit of Parts Transmissions in cad/inventor format. If possible email the items to Pnakovich89@aol.com or post a link with a downloadable copy. Thank you for your cooperation.
Unread 09-05-2007, 15:12
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: 2006 Kit of Part Transmission
Not too sure which one you are referring to, the following place has a bunch of this stuff:
http://www.firstcadlibrary.com/
Jacob
Unread 09-05-2007, 15:30
Pnakovich's Avatar
AKA: Paul Pnakovich
its not on firstcadlibrary, and the 2006 kit of parts transmissions are the big gray metal box ones that have 2 cim motor inputs.
Unread 09-05-2007, 15:34
AKA: Jacob Komar
These?
http://andymark.biz/am-0011.html
If that's it, the link is near the bottom for the CAD file. It says that these were designed for FIRST... so they could be them.
I've been in FIRST for 3 years now... but im a programmer
Jacob
Unread 09-05-2007, 15:54
Originally Posted by whytheheckme View Post
These?
Nope. The 2005-2006 trannies were custom for FIRST, but they weren't AndyMarks. Similar size, different configuration. (And no, I don't have a CAD version. I used gray blocks when I was blocking things out in 2006.)
Unread 09-05-2007, 18:25
AdamHeard's Avatar
Lead Mentor
I have them on a DVD of previous years robots. I'll upload it tonight after work.
Unread 11-05-2007, 20:59
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
You should be receiving them in an email from me
Unread 11-05-2007, 23:26
Pnakovich's Avatar
AKA: Paul Pnakovich
yup, this looks very good. Thank you, I appreciate this, i tried to make it but was unable to find the info to build the inards. this helped out alot.
Unread 12-05-2007, 16:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Here's the link to IFI's CAD model of the 2005/06 Season Kit transmissions:
http://ifirobotics.com/docs/Drivetra...rts%20STEP.zip
If you have access to CNC fabrication services, it would be easier to reproduce the AndyMark single-speed transmission as opposed to the IFI ones.
The AndyMark transmissions are essentially exactly the same as the IFI trannies*. The IFI transmissions however used a custom cast aluminum plate (which would be much harder to reproduce), whereas the AndyMark transmissions have two machined 3/16" aluminum plates, with a piece of square box aluminum around the outside. (You could probably eliminate this square box and just use aluminum hex/round stock as spacers if needed instead.)
* The IFI transmission had a 12.755:1 ratio, where as the AndyMark has a 12.75:1 ratio.
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-05-2007, 12:36
Pnakovich's Avatar
AKA: Paul Pnakovich
after i downloaded these files, i tried to look at them but they were a type of 3ds max format files, are there inventor files?
Unread 15-05-2007, 12:44
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
The files from AndyMark are "step" files. They will come in as blobs known as the base. You can modify them but can not edit existing features. You can add/subtract features. When you save they will be .ipt.
BTW, both AndyMark and IFI have the same ratio.
Andy Brockway
Team 716, The Who'sCTEKS
2007 Kit Transmission Brandon Holley Rumor Mill 1 06-01-2007 01:40
pic: Kit Transmission Upgrade kit Andy Baker Extra Discussion 17 29-01-2006 01:27
Kit Transmission KillerCows456 Motors 17 28-01-2006 17:10
kit part exchange program Team:1223 Kit & Additional Hardware 2 26-01-2004 10:21
