Flat-file systems vs Software DBMS
So since this forum has been rather quiet lately, I thought i'll post this to generate some discussion.
The news: PQL, TDB and txtSQL are doing a joint benchmark! The aim of this benchmark is to give ourselves a better look at how we (flat-file DBMSes) compare to each other and mysql. Not going to delay this anymore, just check out what im talking about. This is incomplete and only contains the PQL benchmark. The txtdb and txtsql equivalents will be written by the authors of those systems. txtdb is at version 5.2, txtsql at 2.2 and pql, being the youngest, is at 0.7.Anyway it'll give you an idea of where i've gotten with PQL since version 0.4. Some of you might recall I've brought up PQL here before (thread probably already archived), but since then , its improved by leaps and bounds. The querying capability of PQL still is my proudest acheivement, and I've made several very cool innovations to increase the speed of the queries 20 times. There is also a (almost global) shadow cache system in place to control memory leaks and unnecessary file reads that killed 0.4's speed. I can't say anything about txtdb and txtsql cause i don't know them as well, but we are all definately very interested to see the final results of this benchmark. It should change the way people think about flat-file systems (buggy, feature poor, slow, prone to corruption). What do you think? Last edited by Gigaman2003 : 12-05-2007 at 12:32. |
Re: Flat-file systems vs Software DBMS
Though you appear to be making a lot of progress I would hold off on calling your system a relational DBMS until you can verify you follow E.F. Codd's 12 rules.
funny you should mention that, I was planning to make the next version ACID compliant and during some googling came acoss those 12 rules. either way, there are only two rules PQL 0.7 dosen't follow, and thats the support for null fields and high level insert, update and delete. ive already fixed that, and PQL0.8 fully conforms to the 12 rules. ACID compliance is still in progress though, I'm having trouble finding a way to do that without killing the speed too much
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| The World is Flat | Beth Sweet | Chit-Chat | 0 | 23-10-2005 22:16 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
