Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Unread 12-05-2007, 16:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: 2006 Kit of Part Transmission
Here's the link to IFI's CAD model of the 2005/06 Season Kit transmissions:
http://ifirobotics.com/docs/Drivetra...rts%20STEP.zip
Originally Posted by Pnakovich
yup, this looks very good. Thank you, I appreciate this, i tried to make it but was unable to find the info to build the inards. this helped out alot.
If you have access to CNC fabrication services, it would be easier to reproduce the AndyMark single-speed transmission as opposed to the IFI ones.
The AndyMark transmissions are essentially exactly the same as the IFI trannies*. The IFI transmissions however used a custom cast aluminum plate (which would be much harder to reproduce), whereas the AndyMark transmissions have two machined 3/16" aluminum plates, with a piece of square box aluminum around the outside. (You could probably eliminate this square box and just use aluminum hex/round stock as spacers if needed instead.)
* The IFI transmission had a 12.755:1 ratio, where as the AndyMark has a 12.75:1 ratio.
Art Dutra IV
世上无难事,只怕有心人.
2007 Kit Transmission Brandon Holley Rumor Mill 1 06-01-2007 01:40
pic: Kit Transmission Upgrade kit Andy Baker Extra Discussion 17 29-01-2006 01:27
Kit Transmission KillerCows456 Motors 17 28-01-2006 17:10
kit part exchange program Team:1223 Kit & Additional Hardware 2 26-01-2004 10:21
