Go to Post this is robotics--everything is going to go wrong at some point, it's how we deal with it that counts - abigailthefox [more]
Unread 11-05-2007, 11:22
gaby1367 gaby1367 is offline
Driver (Ret.)
AKA: Pablo
FRC #0714
gaby1367 is an unknown quantity at this point
problem with speed controller
we have one of the transmision put to operate our arm and when you conect everything else and try to move the arm with the speed controller the light goes to red and it stop the power suply to the moter momentarily and then resets this keeps happening over and over. how can we fix this?
Unread 11-05-2007, 11:42
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: problem with speed controller
Do you have the supply hooked to V+ and V- and the motor hooked to M+ and M-
V+ should go to circuit breaker panel (30 amp possibly 20)
V- should go to ground
My guess you have something hooked up backwards and shorting out because the Victor 884 will shut itself off before serious happens or your 30 amp is bad and keeps tripping and resetting itself (you should be able to hear the clicking if that is it)
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 11-05-2007, 12:18
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Also check to make sure your battery isnt so far gone your RC is resetting... or that you used too light a guage of wiring...
If your radio is located near the motor or is using out-of-date firmware, it could be resetting due to magnetic flux from the motor.
Is your gear ratio large enough? Perhaps the motor is encountering too much torque.
Gimme a yell if any of that works or doesnt...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 11-05-2007, 12:32
Gamer930's Avatar
AKA: Justin
Ya that could be another thing, with all the problems with the 2007 radio, I would try and tether to make sure you got a solid connection between the RC and OI also
Unread 11-05-2007, 20:22
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
What's shutting off? Is the motor just stopping or is the light on the speed controller turning off. If the motor is just stopping, make sure that everything is mechanically alright and that your software is correct. If the light is turning off, check on your breakers (and wiring).
Actually, if you swap the supply and motor wires, it can't protect itself. And it'll be damaged too fast for the breakers to protect it. Actually...if you use a small enough motor, it may be enough to stop it from blowing up. But either way, it won't be self-protecting.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 11-05-2007, 21:44
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
The speed controllers should blink yellow without a PWM input. Once a signal is identified, they will be solid yellow( or orange). If the speed controller turns red, this means it has lost it's pwm signal through a hardware fault, or through a high current fault.
Check your software. Do not switch too fast from 127 to 255. This will create a current surge in the controller, and over time, damage the controller. It is always better to pass through (127) briefly before changing direction, or gradually increase the speed from 127 to the desired speed. Do not make the $120 mistake. You will not even notice the slower transition either, since we are talking milliseconds in delay times.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 11-05-2007, 21:48
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Red actually means full reverse, not a problem with the 884, just wanted to make sure the LED color signals were clear.
Originally Posted by IFI Manual
LED Indicator Status
• Green = Full Forward
• Orange = Neutral / Brake
• Red = Full Reverse
• Flashing Orange = no PWM
Ricky Quinones
Director of Sales - VEX Robotics
Unread 11-05-2007, 23:09
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
it could be that the h bridge on the victor is blown. it happened to us at LA, lucky we had a spare. one of the none electrical people put the m+ and m- together. how exactly is the light behaving. because going to red is normal because its indicating its on reverse, but were you trying to go reverse or forward. and is it only the victor thats turning off or the whole system.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 11-05-2007, 23:17
Not to discount the IFI manual, but we have had 884 controllers in the past blink red that we traced to damaged controllers. They still were operational, but were not repeatable to the PWM input signals being sent.
A 30 Amp breaker will not protect the 884 from a 50+A momentary spike if changing direction too fast. This spike is in micro-seconds, a breaker will average currents over a period of time. All of that momentum from full forward to full reverse has to go somewhere. The current spike is probably not measurable, but over time, if done enough, will breakdown any circuitry protection built into the 884.
This year we implemented controlled speeds to the controllers. We haven't lost one yet. We cannot say that for the previous 2 years.
Jim E.
Unread 14-05-2007, 17:37
To go along with the original problem and folllowing up on Ricky's post...
A flashing red indicator is likely from the controller getting a full reverse command and the breaker tripping. There is no flashing red programmed into the controller. It sounds like the motor wiring is shorted. That way high currents are developed when the controller is told to apply power to the motor.
Unread 14-05-2007, 19:27
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
i don't know, but could it be your program?
Unread 14-05-2007, 22:16
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Here is a link to the user guide for the 884: http://ifirobotics.com/docs/ifi-v884...al-9-25-06.pdf
I agree with Al... It sounds like you have a short from the motor output side. I think that this can also happen if you have the brake set and you have the input side mixed up with the output side. The input side is where the PWM cable comes into the victor. Another idea is that something is shorted over the transistors under the cooling fan. Simply take off the fan and inspect each transistor for any metal shavings. I would look at all the other victors as well and compare it with this faulty one or replace the victor and see if a new one works. There are many combinations of things that could be going on.
The only diagnostic red blinking light on the victor would be after a failed calibration.
To calibrate follow the directions below.
User Calibration:
1. Power ON the speed controller.
2. Press and hold the Cal button. After a moment, the
LED indicator on the Victor will begin alternating
between RED and GREEN to indicate a cal mode.
3. While continuing to hold the Cal button, move the
joystick to the maximum and minimum positions.
This can be done in any order and as many times as
desired.
4. While continuing to hold the Cal button, return the
joystick to center (neutral position).
5. Release the Cal button.
6. A flashing GREEN indicator confirms a successful
calibration.
7. A flashing RED indicator denotes an unsuccessful
calibration.
An unsuccessful calibration occurs when either:
a) Insufficient joystick travel was detected in forward
and/or reverse.
b) The trim tab is too far from center.
Resetting Calibration to Factory Pre-calibration:
1. Power OFF the speed controller.
3. While continuing to hold the Cal button, Power ON
4. A flashing GREEN indicator denotes calibration is
reset. Release the Cal button.
Hopefully this helps out...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
Speed controller Problem fixer upper Andrew Rudolph Control System 2 21-02-2005 08:22
Speed controller Problem fixer upper Andrew Rudolph Electrical 2 21-02-2005 08:22
trouble with pwm speed controller jakk Control System 4 10-01-2005 02:51
trouble with pwm speed controller jakk Electrical 4 10-01-2005 02:51
