Go to Post ...when you hear a kid say "oink oink" and you say in your head "BOOM!" - delsaner [more]
Unread 14-05-2007, 22:53
nonother's Avatar
nonother nonother is offline
Founder
FTC #3053 (Occam's Engineers)
nonother will become famous soon enoughnonother will become famous soon enough
pic: Differential Swerve (Close Up View) with Advanced Gear Kit
Unread 14-05-2007, 22:54
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: pic: Differential Swerve (Close Up View) with Advanced Gear Kit
That differential looks almost identical to the LEGO ones. Is it fairly easy to assemble? I know I've always had a heck of a time getting the LEGO ones together
Unread 15-05-2007, 09:12
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I remember when I assembled my first lego differential based vechicle.... It made me crazy to put it together but jeesh was i happy when it was! I'll have to get my hands on one of these, always have been facinated by differentials.
Great job on the assembly!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 15-05-2007, 09:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, this was my weak point when working on the race car back in high school -- I was more of an engine & electronics guy. What is the point of a differential for those of us who can't visualise why you'd want 2 wheels turning in opposite directions on the chassis setup you have for this particular bot?
GitHub
Unread 15-05-2007, 14:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
In the differential in a car, the wheels do NOT normally turn in different directions; (although it is possible) rather they turn at different speeds. When you drive around a corner, the outside wheel has to turn faster (bigger radius circle), and the inside wheel has to turn slower (smaller radius).
The way this is achieved is that the entire body of the differential can spin, causing one of the output shafts to spin slower that the other. (It's kind of hard to explain in words, these links may be of some help:
http://auto.howstuffworks.com/differ....htm/printable
http://en.wikipedia.org/wiki/Differe...hanical_device)
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-05-2007, 15:07
Nuttyman54's Avatar
Mentor, Tactician
I've used differentials like this for various applications, usually when I need an output shaft to be able to switch from rotating with the input to rotating opposite. This can be done by allowing the entire differential casing (as shown here) to rotate, or by locking it up.
Unread 15-05-2007, 15:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Is the differential the only thing that comes in the "Advanced gear kit"? Does it come as one unit, or does it have to be assembled? I assume the bevel gears could be used for other applications?
Unread 15-05-2007, 16:16
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
The kit comes with the differential frame, bevel gears (which can be used in the differential or for other applications), rack gears and worm gears (plus a few spur gears to use with the worm and rack gears).
You can see the contents here: http://www.vexlabs.com/vex-robotics-...gear-kit.shtml
Unread 16-05-2007, 01:14
CraigHickman
Posts: n/a
I should get those so I can build a coaxial crab...
Looks sweet.
pic: A Better View of Racky With All Cylinders in Stowed Position DanDon Robot Showcase 2 20-02-2007 21:06
Help with the Kit Gear Tooth sensors Keo-san Programming 9 20-02-2007 08:07
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
Need help programming our swerve with feedback? activemx Programming 25 13-04-2004 07:29
Close Encounters with Team 48 SwordSerenity Chit-Chat 7 13-02-2003 12:26
