Go to Post We will be stressed, we will be angry. But we need to hold ourselves to a higher standard, we need to be role models and inspirations to students. - Andrew Schreiber [more]
Unread 16-05-2007, 13:23
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Pascal-like language debugging?
I'm trying to debug my program on one of the robots at work. Unfortunately, the program has a function which calls out another function which calls out another function or two, and so on. I've put in a line to print out so that I know if it reached a step.
The problem is that it appears to be an issue with the function called out immediately before it. I have yet to look at that particular function, but it deals with analyzing the image and I'm not sure I'll understand it since I didn't write it.
Is there something else that I can try doing? I'm not a programmer by trade, so any suggestions would be appreciated. (Esp. since I will programming another robot once I get this code tweaked.)
Thanks,
indieFan
Unread 16-05-2007, 17:49
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Pascal-like language debugging?
Why is this related to Pascal? Isn't it in C? or does that function include Pascal code?
In any case, if it's a basic FIRST code, I doubt there's any reason to work with pascal unless it's a function related on making the codes you enter operate properlly on the robot.
If the debugging arrow shows an arrow at the begining of the page of the function, then you forgot something in the function listed(notice, not called) before it.
A little more detail on the problem would help.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 16-05-2007, 18:21
FRC #5941
Actually, this is work related. It is a non-FIRST robot. In fact, the robot that I'm dealing with is probably older than any of the high school students in FIRST this year. Hence, the language is Pascal-like.
Anyway, I managed to find out that it was an issue with the coloration of the image. I'm working on trying to fix that, but one of my other robots went down and is more critical.
indieFan
Unread 17-05-2007, 02:43
AKA: Nir Levanon
I already got used to robots=FIRST.
2008 Robot Driver
2007 Robot Driver.
printf/debugging yogibear Programming 1 16-11-2006 20:08
Wireless programming and debugging link heydowns Programming 2 23-01-2006 21:39
Making Debugging Easier dm0ney Programming 18 10-04-2005 23:32
Dynamic Debugging Tool MarkVH Programming 5 04-02-2005 18:09
Learning PASCAL and BASIC Aignam IT / Communications 12 06-07-2004 22:05
