Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Unread 16-05-2007, 19:25
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
pic: 2007 Robot Brain
Unread 16-05-2007, 19:26
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: pic: 2007 Robot Brain
wow that a lot of stuff in a little space, didn't your victors get really hot
Unread 16-05-2007, 19:29
Stephi Rae's Avatar
Stephi Rae Stephi Rae is offline
Lets play robots!
AKA: Stephanie Morrison
FRC #5803 (Apex Robotics)
Stephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to behold
Send a message via AIM to Stephi Rae
Did you have a muffin fan nearby to keep them cool?
If you didn't, or even if you did I guess... did they give you any trouble?
~Stephanie Morrison (Hoag)~
Student - Team 1983 (2007-2008)
Mentor - Team 190 (2009-2012)
Mentor - Team 1983 (2013-2014)
Mentor - Team 1318 (2015)
Coach - Apex Robotics 5803 (2016-Present)
Unread 16-05-2007, 20:38
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Pavan, if you have a picture of the bottom view of that board, please post it. A lot of people will be inspired after they can see how much weight can be taken out just from one sheet of metal. That is one of the most neat electrical board I have seen all year long. Kuddos to you guys.
Unread 16-05-2007, 21:11
Pavan Dave's Avatar
Busy in College
No sir, we did not have a muffin fan. We did not have any fans besides the ones on the speed controllers actually. If I had more pictures of the different views, you would see that the speed controller fans are mounted to where they air flows in narrow aisles. We did not have problems with the cooling of speed controllers. Also as Arefin mentions in the post above there is a lot of metal cut out of our Cat Plate (the plate that everything was mounted onto (it is called the Cat Plate because my mentor thought it looked "cat-like")) so there is also direct airflow to the speed controllers from underneath.
No sir. They were warm after some hard (demanding on the Victors), close to back to back matches at the Bayou, but never hot.
I will try to get some of the modeled pictures that the controls team made using inventor this year to give you a better idea as to how the bottom looked as well as different views so that you can see how air would flow.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 16-05-2007, 22:34
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Am I the only one that can't see the picture (it doesn't even come up?)
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 16-05-2007, 22:38
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I don't seem to have a problem viewing it, but I threw it up on my site anyway:
http://www.uhsserobotics.com/pavansSickBoard.jpg
Jacob
Unread 16-05-2007, 23:17
Eldarion's Avatar
Jacob
That IS nice!
Firefox must be acting up again, thus I can't see the pic on CD. It happens now and then... Thanks for duplicating it for me!
-- Thomas Paine
-- Anonymous
Unread 17-05-2007, 00:27
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I'll bet the judges gave you a hard time about it. I'm amazed you didn't have any issues with overheating. I know had we put that many victors so close together our mentors would have made us use additional fans!
Just out of curiosity, why did you make it so small? Did you need space or just felt like keeping it compact?
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 17-05-2007, 01:01
Stephi Rae's Avatar
Lets play robots!
Very impressive. I would also like to see that modeled in inventor. we're a rookie team, and i had to come up with our electronics organization this year and used inventor to lay it out... unfortunately we had to do a lot of rearranging... I think that if I were able to compact things like this we would have a lot less trouble next year. If I am seeing things correctly your RC is elevated, right? therefore giving you space to work with underneath, where you keep your backup battery I assume? as well as maybe a spike or two it appears, and a few pwms run under there... right? haha maybe i'm assuming too much, that sounds like a lot of stuff under there, but i guess I wouldn't doubt it seeing how much you fit in the area surrounding the RC.
Unread 17-05-2007, 01:17
Pavan Dave's Avatar
Busy in College
The Cat Plate
I was in charge of inspecting the robot this year again and the inspectors loved that the brain was very organized and that is all they liked , they had some issues with our brain being mounted on top of our fuse panel (20A-30A) but after a flashlight and a screwdriver they lightened up, but insisted SEVERAL times to make everything more visible in the future.
Our reason for making it so small is because of our base. If you see pictures of our robot, we have a very low CG and we had planned the base to place certain key components in certain spots (the V6, Compressor, Battery, Brain). So to answer your question, we space elsewhere on the robot for other functions AND we wanted to make it compact after previous years of our "keep it together" strategy.
Yes sir you are correct, our RC is mounted higher but you are mistaken as to what is under there. Underneath lies our 20A-30A fuse panel. Also on our RC you might notice a piece of Velcro, that is where our backup battery was placed during competition.
1745 - 118 - ΔΕΨ
Unread 17-05-2007, 05:21
CWBWBN's Avatar
CWBWBN CWBWBN is offline
www.boredom-induced.com
AKA: Marcus
FRC #0179 (Swampthing)
CWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of lightCWBWBN is a glorious beacon of light
Send a message via AIM to CWBWBN Send a message via MSN to CWBWBN Send a message via Yahoo to CWBWBN
that is definately the cleanest electronics board i have ever seen for as much stuff is on there!!
mch
<3
Unread 17-05-2007, 06:24
Originally Posted by Pavan View Post
PS. There is a trick to the power distribution block that will be posted soon.
Yeah, something's definitely up with the negative side. It looks like it's split into two sections. What's the deal?
Unread 17-05-2007, 07:58
AKA: Jacob Komar
Yes, It appears that one of the 4 (-) blocks is not connected to the others... and has a lot of stuff going in/out of it.
Now that I look at it better, on the (near) side, it appears there are 4 black wires, appearing to go to the Victors on the right. On the other side is a larger wire, and we can not see where this goes. Perhaps those Victors are grounded separately? for some reason?
Just some thoughts.
Jacob
Unread 17-05-2007, 11:31
AKA: Ari
Take a close look at this picture. It is very cool to see teams planning ahead of time like Gabe said in the other thread.
pic: MVRT115 2007 Robot Ashwin Robot Showcase 11 23-02-2007 14:00
pic: 662's 2007 Robot NK2007 Robot Showcase 2 10-02-2007 20:38
pic: FRC488 2007 Robot Madison Extra Discussion 17 04-02-2007 01:56
pic: 610 Teaser, A Coyote's brain??? Jonathan Norris Extra Discussion 5 29-01-2007 11:04
pic: Your brain on FIRST Elgin Clock Extra Discussion 11 20-04-2006 21:59
