Go to Post In my opinion, leaders do not need to be picked. They naturally emerge as time goes on and as more opportunities are presented to them. - Alex Golec [more]
Unread 17-05-2007, 10:26
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Laser Rangefinders
Does anyone have a source for a laser rangefinder? I'm looking to either make one or buy one, for under $100 each. I've only been able to find two types online, home-made ones that use a webcam as a receiver or using a photodiode ic, but the only ic's i can find only tell if it detects a laser beam or not, they don't give an actual distance.
What I am looking to do is measure distances up to around 100 feet with a laser that operates similar to a UltraSonic, you send a trigger pulse out from your controller and then you count the number of cycles before you get a response, which will give the distance (of course, you have to divide by 2). I don't really care if the one I get works that way or not though, just as long as I can somehow get a distance reading.
Unread 17-05-2007, 10:40
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: Laser Rangefinders
Wouldn't you have to calculate it using the speed of light? Therefore, please correct me if I'm wrong, but it's not possible?
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 17-05-2007, 11:28
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I believe most laser range finders work based on the angle the beam is received at, not the time difference.
Eric Haskins KC9JVH
Unread 17-05-2007, 11:29
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Have you looked at the Stanley 77-910 - TLM 100 FatMax™ Tru-Laser™ Distance Measurer: http://www.stanleytools.com/default....TNUMBER=77-910
It sounds like what you are looking for and they sell for $100 just about anywhere online. It is a true laser measuring device not an ultarsonic with a laser pointer.
Are you just wanting something to buy to measure distance or something to use as a sensor on a robot or something? Maybe you can hack this Stanley unit?
Unread 17-05-2007, 11:32
AKA: Eric Haskins
I'd google that unit. I'm sure if its possible to hack it somebody already has.
Eric Haskins KC9JVH
Unread 17-05-2007, 11:33
DavidGitz's Avatar
Actually there are two ways of doing it without using triangulation. You can measure the time delay, assuming the processor is fast enough. The speed of light is 3*10^8 meter/second. If you have a 80MHz clock on your processor (Propellor with an external clock), that means your step distance is 3.75 meters per cycle (and a minimum distance of 3.75 meters too), plenty close for me, since I will be using UltraSonic's for close distances that work up to 6 meters. The other method is to modulate the laser with a frequency, then you can determine the distance using the properties of the Doppler effect, as long as you're relatively moving
Unread 17-05-2007, 11:35
DavidGitz's Avatar
That's funny, actually I was just looking up that out of desperation. Plan B is to hack another one, but as this robot is actually for production-design, I would like something not so hack-ish.
Unread 17-05-2007, 11:39
AKA: Eric Haskins
You would need a much faster processor than that. You couldn't possibly process the signal every cycle.
I'm just curious what are you building?
Eric Haskins KC9JVH
Unread 17-05-2007, 12:04
I understand. Hacking the Stanley may not be an option anyway: http://forums.parallax.com/forums/de...?f=15&m=174249
I think you may be asking for a tall order to get what you want under $100. If you find something let us know. I have several uses for such a device if it can be interfaced to a microcontroller.
Unread 17-05-2007, 12:10
The CPU doesn't have to do all the work. I know of a system having a 2 MHz processor that still manages to do time-domain reflectometry with better than 2 meter resolution. A separate 75 MHz clock drives a fast counter which controls the pulse generation and detection circuitry.
Unread 17-05-2007, 12:37
DavidGitz's Avatar
Yeah it seems like not many people are having luck, at least with a fairly inexpensive module. I'm sure I could get something to work if I could just find a detector IC that is sensitive to around 690 nm for a red laser pen (cheap emitter As I said before, I found a detector but it only returns either a detected or not-detected value:
http://www.junun.org/MarkIII/Info.jsp?item=79
Unread 17-05-2007, 14:33
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Can't you use interferometry?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 17-05-2007, 14:52
DavidGitz's Avatar
I assume you mean using more than one laser to triangulate your position. I didn't really want to do that, since my goal is to have 4 lasers on the robot, at 90 degree intervals. Using 8 for triangulation would be a bit too much I think
Unread 17-05-2007, 14:58
Eldarion's Avatar
One of these, near the bottom of the page:
http://www.williamson-labs.com/laser-mic.htm
It's pretty complicated though. i think a device of this type *might* be what the surveyors use?
Do a Google search for laser interferometry distance measuring and you might be able to find something better.
-- Thomas Paine
-- Anonymous
Unread 17-05-2007, 17:56
Gdeaver Gdeaver is offline
FRC #1640
Try looking looking on Globalspec for time of flight sensors. Even raw moduals will cost over 100$.
pic: Laser Cutter fun Jay Trzaskos Extra Discussion 4 06-02-2007 11:40
First laser cutting video TriggsJr Robot Showcase 3 06-03-2006 13:19
4.3.4.1 - onboard laser? Ethulin Rules/Strategy 29 15-01-2006 13:13
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
Laser Pointers.. archiver 2001 18 24-06-2002 00:08
