Go to Post Everyone is wrong! - Chris is me [more]
Unread 17-05-2007, 11:49
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Re: pic: 2007 Robot Brain
Originally Posted by Alan Anderson View Post
Yeah, something's definitely up with the negative side. It looks like it's split into two sections. What's the deal?
That's not the trick. The reason for having two of the jumpers was simply that the four wide jumpers were all but impossible to come by this year, and we had a source for the three wide jumpers. Apparently, the documentation for the jumpers says that stacking two jumpers (a three and a two) on top of each other like this is an acceptible way to make a longer jumper.
The trick Pavan's talking about is the rigamarole we went through with the PDB to keep it from becoming loose at nationals. We went through a process of:
1. Removing the crappy slotted screws from the PDB.
2. Turning down nice caphead allen screws on the lathe so that they'd fit in the plastic housing.
3. Crimping and soldering on the end of each power wire an Anderson Power Pole pin.
4. Sanding and bending the pin slightly to become a hook that will fit flat into the PDB.
5. Tightening down the nice new capheads on top of the modified APP pins.
6. Locktite the screws from the side of each PDB section.
7. Tape the part of the APP connector that sticks out from the PDB
This process took an entire fixit window to complete, and although it was tedious and slow, we had not a single problem at the championship, after constantly fixing it at both of our regionals.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 17-05-2007, 11:57
4throck 4throck is offline
FRC #1418 (Vae Victus)
4throck is a name known to all4throck is a name known to all4throck is a name known to all4throck is a name known to all4throck is a name known to all4throck is a name known to all
Wow, that is much better than our electronics. Our mechanical components were all modular, but since the design changed a lot during build season, our electrical components were mounted rather haphazardly, and our wiring looked like a bundle of spit, with some desperate attempts at order. This is definately something to consider for next year.
Unread 25-05-2007, 20:41
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I was finally able to obtain the CAD files of our brain box. If you would like more pictures, drawings, or anything else pertaining these files, I will try my best to get them to you. This is before we designed the cat plate and so there are no holes. I think this is wate Arefin and a few others wanted posted.
http://www.teknobot.net/cadbrain/1.jpg
Enjoy!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Last edited by Pavan Dave : 25-05-2007 at 21:03. Reason: Made pictures friendlier for dialup users.
Unread 28-11-2007, 15:43
AdamHeard's Avatar
Lead Mentor
Those are 45 amp anderson powerpole connectors, right?
pic: MVRT115 2007 Robot Ashwin Robot Showcase 11 23-02-2007 14:00
pic: 662's 2007 Robot NK2007 Robot Showcase 2 10-02-2007 20:38
pic: FRC488 2007 Robot Madison Extra Discussion 17 04-02-2007 01:56
pic: 610 Teaser, A Coyote's brain??? Jonathan Norris Extra Discussion 5 29-01-2007 11:04
pic: Your brain on FIRST Elgin Clock Extra Discussion 11 20-04-2006 21:59
