Go to Post Blame it on the programmer. - colt527 [more]
Unread 14-05-2007, 17:44
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Battery Technology / Electric Vehicles
If you want to retrofit a go-kart, you could pull the drive and controls from a used electric golf car. Most electric golf cars run 24-48v, 3-5hp motors, and have max. speed of ~20mph.
I know you can pickup used golf cars very cheap, if they have bad batteries.
If you wanted to spend a little more you could replace the analog controls, most older golf cars use, with digital controls.
Eric Haskins KC9JVH
Unread 14-05-2007, 18:01
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Originally Posted by John Gutmann View Post
Not to shoot down your idea, but have you considered starting out with trying to convert maybe a go kart? This way it is smaller scale and less expensive. This way you can learn the same amount as you go along with spending less money. Then if/when you move to a automobile you know more. And maybe you can use the go kart to ask for sponsors too?
I like your idea, I have been wanting to do it for a long time, but as with any project money is the issue. How much working are you planning on doing? Becuase if you go with a motor pre wheel design there is going to be alot more work compared to just dropping an electric motor and transmission in. You will also nood to make a ton of parts. I have never personally done this but I have looked at alot of stuff online and for one person, a college student none the less, it is going to be a TON of work.
-John
good idea but is there a way to make it street legal
i found this http://blog.modernmechanix.com/2006/04/03/build-your-own-street-legal-kart/
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 14-05-2007, 22:21
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Originally Posted by Qbranch View Post
Anyhow... I think you'll be seeing an electric go kart around this summer in indy...
-q
Back when I was in Kentucky, we used them Cushman electric trucks for getting around. Well my supervisor and the supervisor from the other shop were in the habit of trying to out do each other in tweaking their shops Cushman to be the fastest, or have the most pulling power.
Ah the memories of cushman drag races in the tunnels on 3rd shift....
and the stinking blue cloud of smoke when you burn up a motor.
Anyhow, you can find old Cushman's for a grand or two... from there you can build all kinds of things out of them.
And if you want to race... I got a buddy in Lexington KY with the fastest Cushman you've ever seen. I could set up a race... hehehe
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 14-05-2007, 22:43
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Well You could easily make a VERY powerful electric go kart from 4 AM 2 CIM 2 speed shifters and 8 small CIM motors. If you saw the video that was posted a while ago ( I don't remember what team ), but they took an old swerve drive module and was driving people around with 1 CIM motor. The frame should be brutally simple. Get a Kitbot frame, I personally would trust it, as the cross section of the rails has great structure vertically. It is easy to mount to and a nice size. You can then use 6 of the 18 AHr Batteries to power it. That should be fine for a nice short ride. You can do a 4WD config with u joints on the front wheels for the drive or do a 4wd with 4 back wheels or chain up all 4 transmissions to the back 2 wheels (my preference). And run a simple steering mechanism on the front. No need for fancy rack and pinion steering. I have thought about doing this ALOT in recent years, but once again lack of money ahs stopped me.
Another thing you could do is go talk to a mini baja team in your area and see if they would be interested in donating a car to the cause.
-John
Unread 15-05-2007, 22:38
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Nimh batteries are NOT the way to go. I have recently turned my back on them when they required constant peaking for max output. They are heavy, loose charge very fast, and must be cycled around every 20 days or so. Lipos is what I use now for my r/c cars/boat/planes/helis. As dt mentioned, with lipo you hold the plane in your hand and give it not even 100% full throttle and just release it. A 6 cell 3800mah NIMH pack weighs a pound, a 7.2V 5000mah lipo pack weighs half of that, holds its voltage longer and allows for larger current draws. However, lipos are dangerous if not taken care of. They do blow up and they do set people's cars/houses on fire if not kept in safe spots. They only do that if cells are unbalanced, or have been damaged but the damage went unnoticed. They are also very expensive . Your idea is a great one, as a matter of fact about 2 weeks ago I started thinking of the same thing, but instead converting something like a hatchback. I looked into it and it seems that a DC motor is more optimal than AC. A brushless motor of that size would be more expensive than brushed, and probably hard to find. DC brushed are sold at websites like this one http://www.electroauto.com/
I'm experimenting with hydrogen right now
Vova
Unread 16-05-2007, 22:14
Protronie's Avatar
Vova
You worry about a battery blowing up?
And now your experimenting with hydrogen?
Good luck on that one!
Ba Da Bing, Ba Da Boom!
Unread 17-05-2007, 15:15
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
I don't particularly like the distinction between AC and DC because of the fact that brushless motors can be run off of both types of power. In an AC implementation you apply an alternating current with an equal phase distribution. In an DC implementation you switch the phases in a certain order just with a DC voltage you can get from a battery. In the long run brushless motors will in fact be more cost effective than brushed because of issues involving wear and maintenance.
Unread 17-05-2007, 21:18
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Oh I never said brushless isn't the way to go because...well...it is! Like you mentioned, no maintenance, more efficient (90%+ efficiency) When I was talking about AC and DC I was talking about brushed, sorry.
I work in a well ventilated area with the hydrogen (aka outside). I'm not producing that much of it either.
Unread 17-05-2007, 22:12
Adam Y.'s Avatar
Adam Y.
no team (?????)
Ahhh.. Now I understand This whole entire issue of motors is kind of confusing for me just because there are so many types. One of the more interesting types I've seen is the switch reluctance which has no magnets inside of the motor which results in no cogging.
Unread 27-05-2007, 00:50
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Ignoring the other posts, dont use the Astro Van as your platform.
Astro's are heavy monsters and are about as aerodynamic as a brick wall.
You also dont want to use the van because vans are a pain to work on.
Just my 2 cents.
Electric Bicycle RudimentaryPeni Chit-Chat 6 05-10-2006 14:24
Outdoor Autonomous Vehicles John Gutmann Technical Discussion 16 13-07-2006 15:52
Electric Solenoids BerserkerSpyke Rules/Strategy 3 01-02-2006 17:36
Electric Solenoid ThomasP Motors 5 10-01-2006 16:47
Gas or Electric?? Clark Gilbert Chit-Chat 14 11-08-2001 12:16
