Go to Post GP is asking for something then having twenty people answer graciously. - synth3tk [more]
Unread 15-05-2007, 17:01
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Animating a Bend
I have been unsuccessful in animating an object to bend, such as a piece of paper. I am trying to get it into a semi-circular shape as opposed to folding. Is this possible in Inventor? Or do I need to use 3DSMax?
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 16-05-2007, 11:04
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Animating a Bend
From my understanding, you have to do it on 3dsmax. However, I would bet that if there was such a possibility with inventor, it would be in the sheet metal section. You might try there if you really do not want to use 3dsmax.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 16-05-2007, 13:33
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
You should be able to do this with the Bend operation in Inventor. You can vary the bend radius and angle parameters to get the shape you want.
Pete Kieselbach
Unread 17-05-2007, 22:39
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
There is a file named something like scissors.iam in the Samples folder with a bending flat spring around an arc.
Check help on Adaptive Sketches and Inventor Studio.
You can animate the bend by Drive Constraint on an angle constraint (I think, I don't have it up to check exactly) - holler back if you can't figure it out.
Unread 21-05-2007, 12:28
Rob2713g's Avatar
Thanks! The scissor animation really helped. I just downloaded 3DSMax, so that should also make it easier.
animating rotation negfrequency Inventor 6 28-12-2006 19:19
Challenge: animating the inanimate JoeXIII'007 VEX 4 22-08-2006 13:55
Bend Radii Andrew Blair Technical Discussion 6 09-11-2005 10:21
Trouble Animating Containers Ryan Dognaux 3D Animation and Competition 3 31-01-2003 19:36
Need Some 3DS Animating Help Ryan Dognaux 3D Animation and Competition 6 24-01-2003 16:30
