Go to Post Overall I really like the idea, and don't be surprised if I borrow some of these ideas for a future robot. - Greg Needel [more]
Unread 18-05-2007, 21:01
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Torque Calculations
I am working on designing a 4-bar linkage arm and was attempting to do some calculations on which motors and gear ratios I should be using. I calculated it at 60in with 20lbs of force. Below are my calculations with a dual-globe motor setup. I came away with an absurd amount of supplied stall torque. If I have 20000 oz-in of required torque, how much actual torque should I be shooting for? I understand that one needs to supply more than just the stall torque, but I don't understand how much of a difference there needs to be between the required and supplied torque. Maybe you guys can help me.
Arm Length: 60 in
Arm Weight: 20lbs
Required Torque = Length * Weight = 19200 oz-in
Motor: Globe
Quantity: 2
Stall Torque: 3194 oz-in
Free Speed: 80 RPM
Gear Ratio: 48:1
Supplied Stall Torque: 306675 oz-in
Motor Specs: http://www2.usfirst.org/2005comp/Specs/Globe_Motor.pdf
I can't find any torque curves.
Thanks for the help
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 18-05-2007, 21:46
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Torque Calculations
Disclaimer Not all of this may be correct. So please don't hold it against me if it is
Okay. Now's a good time to ask this question:
Does having two motors supply more torque? or does it seem that way because there is less load on each motor?
One of our engineers said that our stall torque should be around 25% higher than our required torque. This is to make up for friction. However, that only works if you know exactly where the center of gravity will be and exactly how much it will weigh.
We assumed what the weight will be and where the center of gravity will be so the required torque calculations were definately off.
We aimed to have half of 25% above the required torque (required: 100 lb-ft, stall: 187.5lb-ft)
Also, the center of gravity is roughly the middle of the arm. So if your arm is 60 inches, you should plan on the center of gravity being between 20 and 40 inches from the axel of the arm. (obviously...)
Make sure you are putting enough current into those globes. We made a big mistake this year and calculated what gear ratios we needed based off of the stall current of the FP motors. When we hooked it all up, we were only powering those motors at about 1/3rd the current we had expected and the arm didn't run. That only set us back about a week
Also, with that ratio. That arm is going to move very slowly. If you are planning on using it for a FIRST application, you might want to lower that ratio, cause as it is right now, you've got almost 17 times as much torque as you need. (34 if you lower that length down to 30 inches).
Also. I like working with lb-ft better than oz-in simply because the numbers are smaller and easier to work with
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 18-05-2007, 22:08
in between teams
AKA: Luke Van Oort
I tend to design for 25% stall torque, which keeps the motors from the kit nice and happy for a long time. With some motors this is overkill, the globe happens to be one of them. We actually stalled one for an entire match (programming mistake) and while it was quite hot after the match, it still worked fine fine. (Almost gave one of our team members an uppercut not ten minutes later, actually) Your current design is very conservative, and will be very slow. If you use a 9:1 reduction I think you'll be fine. (This loads the motors to 50% of stall, which would eventually melt a FP or BaneBots, but the globe should handle it fine)
Team 1219: 2009 - Mentor
Unread 18-05-2007, 22:15
AndyB's Avatar
AKA: Andy Burchardt
Thanks for the help guys. My other question is, if I am given a free speed, how do I much is the actual speed affected? How do I calculate it with different amounts of force?
Unread 18-05-2007, 22:39
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
An easy way to do this is to draw out a linear torque-speed curve:
Plot free speed as a point on the speed axis. Plot stall torque as a point on the torque axis. Connect these two points with a straight line. This line defines the torque at a given speed, or the speed at a given torque. (Two ways of saying the same thing, although the dynamic relationship between the two is somewhat more subtle.)
The equation for that line can give you the speed at any torque:
(SPEED) = (FREE SPEED)*[1 - (TORQUE)/(STALL TORQUE)]
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 18-05-2007, 22:48
AndyB's Avatar
AKA: Andy Burchardt
Ok so I did so recalculating. The speed shown is the free speed at that torque. But here is what I get, can someone make sure my math is right.
Stall Torque (oz-in) Free Speed (RPM) Free Current (Amps) Stall Current (Amps)
Minibike 570.00 5310.00 2.70 133.00
Globe 3194.53 79.87 0.58 21.58
Nippon-Denso 1316.99 92.00 2.50 25.00
Keyang 1699.34 85.00 2.00 20.00
Banebots 125:1 4935 134.00 1.00 42.00
Enter Weight (lbs): 20 lbs
Enter Length (in): 40 in
Torque Required: 12800 oz-in
# of Motors: 2.00
Enter Stall Torque: 3194.53 oz-in
Enter Free-Speed: 79.87 RPM
Enter Gear Ratio: 8 :1
Torque Supplied: 51112.48 oz-in
Stall Torque Percentage: 25.04%
Free Speed: 319.48 RPM
1/3 Rotation: 1.77 Sec
Unread 18-05-2007, 23:22
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Since a number of posts have come up since I started the spreadsheet I'll let it speak for the details itself.
Summary:
Your torque required seems high... should be force * arm length unless there are other factors... arm angle also plays into this... looks like there is some 'extra' math creeping in here, possibly applying gear ratio's multiple times
Look at Paul's white paper on motor calcs... http://www.chiefdelphi.com/media/papers/1378
I'm out of time for now, but I check back in the AM.
(AM=morning, not AndyMark, in case clarification is required)
Mark
Mark
Brick walls are for other people. - Randy Pausch
Unread 19-05-2007, 00:06
AndyB's Avatar
AKA: Andy Burchardt
kramarczyk, Awesome resource, thanks for posting, you've just answered all of my questions.
Autonomous calculations Tz0m Programming 5 24-02-2007 06:15
Motor Calculations John Gutmann Motors 3 25-06-2006 08:39
Volume/Weight Calculations in Inventor =Martin=Taylor= Inventor 2 08-04-2006 10:21
Distance calculations Max Brin Programming 3 22-02-2006 21:38
Seeding Calculations archiver 2000 50 23-06-2002 21:57
