Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 19-05-2007, 16:00
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Programming Camera in Easy C
1369/1902 used easyC to track the light with great success this year. Our camera was statically mounted and we tracked the height of the light and as we got closer it moved upward in the field of view. Once we got to a certain height in the field of view we knew we were at the correct distance to cap in autonomous.
If I remember we started with the 2007 kickoff demo code and worked from there.
good luck.
Easy C Relay Programming Team_486 Programming 1 26-03-2007 15:01
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Using Easy C to program the camera. Tazlikesrobots Programming 5 19-02-2006 21:33
Easy C programming , Worth teaching? Nine9cracker Programming 16 19-01-2006 00:45
Easy-C Programming CD Jeff K. Programming 2 09-01-2006 02:20
