Go to Post The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 19-05-2007, 09:12
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
Programming Camera in Easy C
I'm a realitivly new programmer and have been using easy C to program our robot this year. We did not use the camera this year but we are trying to experiment with it in the off season.
I was wondering if any teams programmed their robot with a camera using easy C and if so how you did so. What we want to do is determine the pan to adjust our drive train and then determine the tilt to determine how far we need to drive. If anyone could help, thanks in advance
-Sam
Unread 19-05-2007, 11:53
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Programming Camera in Easy C
Sam
Check this thread out
http://www.chiefdelphi.com/forums/sh...ad.php?t=52003
Good luck!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 19-05-2007, 16:00
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
1369/1902 used easyC to track the light with great success this year. Our camera was statically mounted and we tracked the height of the light and as we got closer it moved upward in the field of view. Once we got to a certain height in the field of view we knew we were at the correct distance to cap in autonomous.
If I remember we started with the 2007 kickoff demo code and worked from there.
good luck.
Unread 19-05-2007, 20:37
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
QC Elite used the camera for the first time this year, also with easyC. Although we did not score in auto at atlanta, we were the only team to score in auto at midwest. We mounted the camera using the pan tilt assy, and wrote a search routine similar to kevins. Once the camera found the light, it tracked it, and we then kept track of the servo outputs to the camera. We used the pan to drive the robot, and the tilt to tell when we were close enough. When the camera angle was high enough, the robot stopped and went through an unloading sequence. The distance worked, but we had a hard time driving the robot straight to the light.
Good luck,
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Easy C Relay Programming Team_486 Programming 1 26-03-2007 15:01
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Using Easy C to program the camera. Tazlikesrobots Programming 5 19-02-2006 21:33
Easy C programming , Worth teaching? Nine9cracker Programming 16 19-01-2006 00:45
Easy-C Programming CD Jeff K. Programming 2 09-01-2006 02:20
