Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 21-05-2007, 12:42
FIRST JerseyKid's Avatar
FIRST JerseyKid FIRST JerseyKid is offline
Alumni
AKA: Erik Cokeley
FRC #0025 (Team Mercury)
FIRST JerseyKid is on a distinguished road
Send a message via AIM to FIRST JerseyKid Send a message via Yahoo to FIRST JerseyKid
Inventor problem
How do you put angles between 3d objects.
I have 3 axles that I want to have parallel to each other but i want lines along the ends that are at a defined angle.
Not sure what to do. I tried making a 2d sketch, project geometry, constrain lines to the center point of the axles end and then putting an angle between the lines. It gives me an error saying over constrained, i think that the projected geometry won't move the 3d shapes.
I also tried using the 3d angle constraint but that isn't what I want also.
Team 1089 alumni coach.
Unread 21-05-2007, 12:46
REVving up for a new season
FRC #2848 (All-sparks)
Re: Inventor problem
if you wouldn't mind, posting a screen shot would help in this situation.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 21-05-2007, 12:55
Alumni
AKA: Erik Cokeley
here i just want to specify the angle between the axles
Unread 21-05-2007, 20:15
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Is this in a part or in an assy, if it is in a part, can you make some lines and just use a fix constraint? Dont worry about constraining them just hold them in place as reference points? If it is in an assy, can you use a combination of angle constraints with the different workplanes of different parts to get them where you want?
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 21-05-2007, 20:22
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I am pretty certain it is an assembly. Looks to me like it is a unique part that I would like to see when it is finished. As far as finishing it goes, I never avoid making 'modifications' to a part to help it constrain better. Just make sure you don't change the part in anyway that will ruin the part. Trust me, it works better then it sounds and when done correctly, the part will look exactly the same even to the well-trained eye.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 21-05-2007, 20:31
David Guzman's Avatar
David Guzman David Guzman is online now
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
I would create two planes at the desired angle then constrain the axis to the planes. It should work fine.
I don't have Inventor right now or i would post a screen shot.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 21-05-2007, 21:33
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
In reality, what will it be that constrains these parts? Your best bet is to model that, honestly, because you may find that artificially constraining parts leads to trouble during manufacturing and assembly.
--Madison--
...down at the Ozdust!
Inventor 11 installation problem aksimhal Inventor 8 17-02-2007 14:44
Odd Inventor problem teamtestbot Inventor 11 07-12-2005 00:20
Inventor Problem w/ saving Pat Roche Inventor 2 14-02-2005 21:36
Inventor problem! Dimension Error squeeks548 Inventor 8 11-01-2005 07:32
Major Inventor Problem Chris Dibble Inventor 5 27-02-2003 11:12
