Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 10-04-2006, 22:44
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
paper: PID Control Theory for FRC Programming
Thread created automatically to discuss a document in CD-Media.
PID Control Theory for FRC Programming by
Matt Krass
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: paper: PID Control Theory for FRC Programming
Great job, helped me out a bunch.
http://www.mikesorrenti.com/
Unread 10-04-2006, 22:51
Just a note:
The equations given in text state the following:
POUT = KP * KERR
But your code shows the proper integer based math method of performing this expression.
POUT = KERR * KP
It's quite clear why the variables need to assume this order, but I did not find it documented that there IS a difference between the "text book" equation and your example.. (it is more accurate to "round" later in the equation, after your numbers have built up.)
Either way, great paper! I plan to include this in my "required reading" for new programmers on my team.
Unread 10-04-2006, 23:59
Matt Krass's Avatar
AKA: Dark Ages
Originally Posted by Tom Bottiglieri
Just a note:
POUT = KP * KERR
POUT = KERR * KP
I'll keep that in mind for the next revision of the paper. Meanwhile if anyone has any comments or suggestions, feel free to post them here, or PM/Email them to me. I hope this paper is of use to everyone and I'm also available to answer specific questions either through CD or the contact information in the paper.
Good luck!
Matt Krass
Unread 11-04-2006, 00:03
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Well written and very clear!
You may want to consider adding some comments to the code examples, such as why you limit to +-127 in case any completely new FRC programmers read this.
Unread 12-01-2007, 15:21
Mike's Avatar
AKA: Mike Sorrenti
I used this paper today as a reference when writing 237's PID control code.
Bumping it up to bring to the attention of other teams.
Unread 12-01-2007, 17:51
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Thank you very much for this paper. This really helped me undferstand the concept of a PID, and will definetly be used when we write our PID code.
-Guy
Unread 19-02-2007, 10:30
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Very helpful. You might want to move the P code example showing the #define KP 5 / 10 to between the P and I sections though, as it doesn't show I control.
I finally learned what this PID stuff is about, thanks.
You might want to also mention that since motor velocity control is a speed you're comparing encoder ticks per time rather than a target value that has a defined range, and therefore also give us a simple method for determining the range, such as maybe start at this many ticks per time period as the min/max, then scale it down when the motor is full and gives less than that number, then printf that max to initialize it to for future code so that it starts out at the right range. I know this really goes beyond the basic PID concept, but it is relevant to speed control.
SEMPER UBI SUB UBI
Unread 19-02-2007, 10:59
FRC #2028
Maybe even add some visual aids, graphs... ?
SEMPER UBI SUB UBI
Unread 18-05-2007, 13:30
kwilliam's Avatar
kwilliam kwilliam is offline
FRC #1038
kwilliam has a spectacular aura aboutkwilliam has a spectacular aura about
Excellent paper!
Matt, this is an AWESOME paper! I wish I had read it earlier when I was learning PID control this year. I read this one instead and had the programming team read it, but your paper is an improvement. Wonderful explanations, good example code, and excellant usage scenarios! I will be sure to include a link to your paper in our own programming team's handbook.
Unread 18-05-2007, 17:23
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Excellent paper!
[dotdotdot]
i'm a new programmer, and well, i don't understand how this works....i sort of understand the concept...you get feedback somehow from the robot....ya...that's about all i understand....
Unread 21-05-2007, 09:46
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Originally Posted by tseres View Post
[dotdotdot]
A little off topic, but, if you need some help with the interfaces to sensors and such, i'll be happy to help. Also, check out this post on on-chip peripherals and this one on encoders..
If you are going to IRI, just come by the field and you'll see the 1024 pit area. Ask anyone on the team for "Q" and they'll point you in the right direction. Good luck!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 21-05-2007, 12:29
tseres's Avatar
thanks so much....although i wont be going to IRI...lol....but thanks
Unread 23-05-2007, 17:25
tseres's Avatar
ahhhhh...after looking at a lot of other things....
so i guess PID is basically having software control the robot rather than just the PWM outputs are the same as the joystick values...so there's a layer of software that processes all the input and output data.
Unread 23-05-2007, 17:54
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Exactly. Programming this way makes you paranoid--you start to trust the code, have a sensor go bad on you, the arm takes off and tries to rip the control system off the robot while destroying a gear box (BaneBots... ) and you don't hit the disable switch fast enough. (true story, times about 50 this season )
But don't let that steer you away from a smarter robot. The pros greatly outweigh the cons. For example, auton becomes easy.
Good luck,
Jbot
Aren't signatures a bit outdated?
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
White Paper Discuss: An Introduction to C Programming for First Robotics Applications CD47-Bot Extra Discussion 10 26-11-2004 21:54
White Paper Discuss: Official 2004 Introduction to Programming Guide CD47-Bot Extra Discussion 4 26-01-2004 20:59
control system programming archiver 2000 17 23-06-2002 22:14
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
