Re: TTL serial max power
Yea but that doesn't mean you can safely pull an 1 amp through the chip. if the TTL serial port is connected to the uC then you can only source ( or sink ) as much current as a general IO pin because that is basically what the pin is.
-John |
| Noisy power supply interfers with rs232/ttl | Mike Mahar | Programming | 1 | 27-01-2007 22:02 |
| 2004 Edubot Serial String Help (TTL in) | Josh Siegel | Programming | 6 | 10-12-2006 08:28 |
| TTL port to a serial port on a demo board | ImmortalAres | Programming | 16 | 09-07-2005 23:44 |
| TTL Serial Port and PS2 Mouse Interface | cbolin | Electrical | 8 | 29-12-2004 15:00 |
| Max mechanical power of motors, how is it useful? | Ken Leung | Motors | 1 | 09-11-2001 14:15 |
