Go to Post Success is the gleam in a child's eyes when they catch their first glimpse of your creation and their life is forever changed. - SlamminSammy [more]
Unread 24-05-2007, 14:02
FRC #0701 (RoboVikes)
Re: Accelerometer use
Here is some info on a Filter you can use to help cancel out noise if you are interested:
http://en.wikipedia.org/wiki/Kalman_filter
It is kind of dense and hard to understand, but I think it would be possible to implment if you got some outside help.
You may also be interested in page 668 of this article:
http://robots.stanford.edu/papers/thrun.stanley05.pdf
I think it might be better to get creative and come up with your own way of filtering out noise, you can use multiple sources (Gyro, Encoders, accelerometer) and based on correlations figure out which ones are accurate and which ones aren't
Team 701
Unread 24-05-2007, 14:58
I am reasonably sure that that is exactly what a Kalman Filter does: Take a whole bunch of noisy measurements and boil them down into one less noisy measurement. Unfortunately, I think that using an accelerometer as a noisy gyro is weak at best. I do like the use of encoders though.
Please take what I say with a hefty grain of salt, as my education for Kalman filters is hilariously spotty. I was helping to interview candidates for a position at Olin, and as a result I heard 4 or 5 introductions to SLAM (Simultaneous Localization and Mapping). Each professor would then gloss over Kalman Filtering with varying degrees of success.
I think it would be a great project to do a white paper on Kalman Filtering as applied to an IMU for FIRST. Take a kit bot, add a gyro, accelerometer and a pair of encoders. This gives you some degree of redundancy, as either the gyro/accelerometer pair or the encoder pair could do all of the work. Then you can combine their data for a more robust system.
Enjoy
If you have to use dial-up, don't use NetZero JBotAlan Chit-Chat 7 18-12-2006 01:39
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
Accelerometer railerobotics Programming 1 27-01-2006 02:59
Accelerometer buss Electrical 1 09-01-2005 00:10
Accelerometer Use Doug G Programming 2 15-12-2004 09:06
