Go to Post It's important to know that it isn't always best to have biggest machine out there. - Quatitos [more]
Unread 30-01-2006, 20:45
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Encoder Code
Originally Posted by farmer
Kevin,
Does your encoder code work with the GTS provided this year (seeing you don't have specific GTS code posted yet). Reading thru your encoder code it sounds like you have programmed several of the things we wanted to do this year. Thanks for your help as always.
Yes, just use interrupts one and two and remove the phase-b sensing code.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-01-2006, 22:13
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Encoder Code
-Kevin
So, so much for the GTS sensing reverse direction.......we're using Hall effect sensors (paired with one slightly offset for phase-b) and they're working great
Jon Mittelman
Team236
Unread 31-01-2006, 21:11
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Encoder Code
The kit GTSs can do direction (different size pulse in each direction), it's just that the pulse is so short that I don't bother. Plus, we never expect our motors to go the wrong way. (Meaning: If they were, we'd have larger issues.)
Unread 03-02-2006, 17:07
farmer farmer is offline
Tired Mentor
AKA: Matt
#1108 (Panther Robotics)
farmer is an unknown quantity at this point
Re: Encoder Code
-Kevin
Thanks a bunch! We will give it a try.
Unread 23-05-2007, 19:03
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Encoder Code
question: in the encoder code, how can it tell velocity? do i have to count the ticks over a certain time? an example is if i have an encoder on my two drive wheels and i want them to go the same speed. i would know how to adjust the motor speed, but how do i get the actual wheel velocity from the encoder?
Unread 23-05-2007, 19:32
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: Encoder Code
ticks/time is the way to go. The velocity is a translation of ticks to wheel
circumference. It helps if you have a fair number of ticks/rev so you can keep the time interval short. Otherwise, it is hard to differentiate stopped (0 velocity) from very slow. A short interval also reduces issues raised by velocity change during the counting interval. The problem with large # of ticks though is you get flooded with interrupts if the robot is moving quickly.
You need to optimize based on what you want to accomplish. Understanding what you are using the velocity value for (and how accurate you need it to be) should be a driving factor in setting up your encoder code.
Unread 23-05-2007, 19:56
tseres's Avatar
Re: Encoder Code
also, do i have to use kevin's code with all of the initialization? or could i make my own based upon the phase a and b on the digital inputs?
*EDIT*
is there also a way i could have the encoder counting in the background of my code? or does it do that already....if not, how (if possible).
from looking at the code, do i also have to reset the encoder count? do i also have to manually make the ENCODER_x_COUNT increment every time the encoder ticks?
Unread 24-05-2007, 14:19
ericand's Avatar
AKA: Eric Anderson
Re: Encoder Code
*EDIT*
You really want to use the interrupt capability (Digio 1, 2) for the Phase A.
I suppose you could do it without interrupts, but you would have a lot of overhead and I don't think you would be able to get the accurate counting that you need.
If you are not familiar with interrupt service processing, I would say use Kevin's code with as few modifications as possible. As you understand more about how it works, then experiment with changes.
Kevins code has the encoder tick counting handled at interrupt level, so it is done effectively "in the back ground". Note that the encoder count is incremented (of decremented) in the ISR. (Interrupt Service Routine)
The question about resetting the encoder count depends on what you want to do, and how many ticks you are expecting. I generally find that using a "long" to store the count will let me count for way more than the amount of ticks I could get during a match time. This does mean that you need to store copies in routines that are measuring an elapsed distance.
Note also that I use "long" and not "unsigned long" since the code counts backwards when (negative) when the drive is reversed. If you have a system with encoders where you can not detect rotation direction, you may want to zero the count whenever you stop.
To compute velocity, one of the timers can be used to provide accurate interval info. Based on the timer, you can run a routine periodically that computes the velocity over the time interval.
Unread 13-08-2007, 12:57
AdamHeard's Avatar
Lead Mentor
Re: Encoder Code
I know it's been a while, but I'm designing the ratios for our prototype base now....
how many interrupts per second can the processor handle?
Our highest gear puts the encoder shaft at about 1500 rpm. We're using the grayhill 128's that Kevin reccomends (because we already have them) and that puts out a lot of counts per second , 1486.6 [rpm] / 60 [seconds/min] * 128 [counts/rev] = 3172 counts per second!!!, and that's only one side. That seems like way too much to me.
can anyone confirm this?
Just saw grayhill offers lower res in the same package. Both the 32/25 look good with 793 and 620 interrupts per second at full speed in high.
Still, I would like to know what the processor can handle.
Unread 13-08-2007, 15:08
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Encoder Code
As I recall, it can handle somewhere in the 5000-7000 range. Keep in mind though, that your encoders will probably not be your only interrupt events. Serial communication (i.e. to the camera) & ADC conversions both also count as interrupts. You may also just have a clock running for other timing.
Something else to consider: where are you putting your encoder, relative to the motor, gearbox & wheel? I would suggest putting it close to the wheel.
Let's suppose you have 10" diameter wheels (fairly large by FIRST standards). That means you have a 31.4" circumference. If that's in a 1:1 ratio with your encoder at 128 ticks per revolution, that means you get an encoder tick every 1/4" of linear movement. That should be sufficient. (I usually aim for 1/4"-1/2" per tick, which has always been more than enough.)
Suppose instead, you have very small wheel - 12" circumference (about 4" dia), and a very fast robot - 20 ft/sec. That means you get 128 ticks per linear foot, and 2560 ticks per second (and 0.1" per tick) at full speed. Double that to count both sides, and you're only at 5k interrupts per second, assuming you're traveling at full speed with both wheels.
If your robot is at a more reasonable speed in the 10-14 ft/sec range, and your wheels are typical FIRST wheels in the 4"-8" dia range, and you have a 1:1 ratio between the encoder and the wheels, at 128 ticks/rev you'll have a good balance among ticks/second, ticks/inch and total interrupts.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 13-08-2007, 15:56
AdamHeard's Avatar
Lead Mentor
Re: Encoder Code
We're using all dead axles so It's far easier to mount it on the gearbox output shaft. There is a either a 12/28 or 16/28 (depending on how many motors were using in the drive) reduction. The stats above are for the 16/28. Also, the res for above is .33 and .43 inches. [also, the sprocket ratio only effects the resolution]
I think we'll go with 64 counts. That gives us about 1586 ticks per second (per side) and a res of .17 inches. That leaves plenty of interrupts open for possible future addons.
Does that sound good?
Unread 14-08-2007, 08:41
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Encoder Code
We used the 64 Grayhill encoder back in '06 with the speed of our shooters (~1300 rpm) and they worked pretty well for us. We stayed away from the 128 model, way too much resolution at that speed, expecially for that application where all we needed was velocity, not position.
Unread 17-10-2007, 22:12
emersont49 emersont49 is offline
#1098
emersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of light
Red face Re: Encoder Code
I read the encoder_readme.txt and encoder.h files but I didn't find out how to disable unused counters. I tried commenting out the ENABLE_ENCODER_X entries in encoder.h but that didn't work.
Any details on how to disable unused encoder channels?
Thanks again Kevin. I'm really looking forward to using this.
Tim Emerson
Unread 17-10-2007, 23:28
Re: Encoder Code
You could cut the number of interrupts you are handling down by about a factor of 4 or 5 and see absolutely no change in performance. I would bet my shiny new iPhone that no FIRST robot ever has, or ever will, be accurate to 0.17". You may want to shoot for a resolution of .5 or 1 inch. It will drop the the cost of your hardware solution and save your programmers a whole bunch of headache. While the amount of interrupts you are looking at are in the theoretical limits of what the PIC can handle, your program will have to be very robust and optimized to not crash the system.
Unread 18-10-2007, 02:51
FRC #2429
Re: Encoder Code
It seems the encoder_readme.txt file directs you to instructions in the encoder.h file that I forgot to include . Until I get around to fixing this, you should be able to disable individual channels by commenting out the associated #define ENABLE_ENCODER_n line in the encoder.h file.
-Kevin
Kevin Watson
http://kevin.org
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
