Go to Post Teamwork gracious professionalism robots = FIRST Robotics - Bcahn836 [more]
Unread 25-05-2007, 13:03
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: XBOX button
usb controllers that the chicklet supports have more buttons than the analog OI port can handle. we used the 360 controller this year. i'm pretty sure you can use the giant X button, but i'm not 100% sure cez we didnt. in the chicklet manual it shows the different "modes" some modes allow more buttons than axes. if you intend on using both joysticks, then you'll only be able to use 4 digital buttons. but, if you only choose to use certain axes, you can use more buttons. what the chicklet does is takes unuses analog channels and assigns each bit a digital value.
0000 0000 - this is a BYTE, or 8 BITS
when you use the extra buttons feature, the last 4 bits of an analog byte get assigned values
0000 0001 - this is what happens when a button assigned (when you onfigure the chicklet...instructions are in the manual posted above).
in binary, this is a value of 1
0000 0010 - this is a value of 2
0000 0100 -this is a value of 4
0000 1000 - this is a value of 8
0001 0000- 16
0010 0000- 32
0100 0000- 64
1000 0000- 128
this is all you need to know. so when you configure the chicklet and press the buttons you configures to it, the actual analog output going to the OI equals one of the above.
so lets say the A button is 8....to make the robot way that the A button has been pressed would look like this:
if(p1_aux==8){ //p1_aux is the auxilary analog channel on port 1
Do_something(); //when the button is pressed, insert what you need
this is just an example, but this is basically how the chicklet works. read through the manual for more. if you need and more help, feel free to PM me.
good luck and have fun
~tseres
Unread 25-05-2007, 13:31
Re: XBOX button
Originally Posted by tseres View Post
...when you use the extra buttons feature, the last 4 bits of an analog byte get assigned values...
...read through the manual for more...
Read through the manual for the correct information. It's the top four bits (128, 64, 32, 16) which represent digital switch values. You should test the individual bits rather than the analog value as a whole, as the lower few bits cannot be guaranteed to be consistent.
There are 17 supported buttons on an Xbox 360 controller. The Chicklet can assign any 12 of them to be sent to the joystick port, four as "real" switch inputs and eight encoded in the Wheel and Aux analog values. Using it this way means you can only get "real" joystick values from two of the possible four axes on the controller. You can choose to get x and y inputs from both the left and right joysticks, but that restricts you to a total of four switch inputs. This is all in the Chicklet manual.
Unread 25-05-2007, 13:33
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: XBOX button
Ok, that should be more easier to understand. Thanks.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 25-05-2007, 15:39
tseres's Avatar
Re: XBOX button
my mistake. but the concept is still the same. i have some code we used this year. i'll post it later when i can find it.
xBox akedomakona Chit-Chat 29 31-03-2007 14:58
who has xbox live Masterfork Chit-Chat 9 16-08-2006 21:50
XBox 360 Joe Matt Chit-Chat 83 29-11-2005 15:18
XBOX PEOPLE, HELP Freddy Schurr Chit-Chat 5 25-06-2005 12:21
Xbox 360 zdeswarte General Forum 1 11-05-2005 14:53
