Go to Post Our wheels just keep falling off. - SenorZ [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 28-05-2007, 15:32
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Re: HDD crash, need help recovering data!
I am not an apple person. Is there a way to start your computer in what microsoft calls safe mode. If you can do it then copy the files you need to your external hard drive. The after you get a new hard drive installed you can copy your files back to the new drive.
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 28-05-2007, 15:42
Billfred's Avatar
Billfred Billfred is online now
If it's not seeing it, I doubt that safe mode would do it. (But, since you asked, you hold down the Shift key right after the startup chord.)
One solution that appears to work long enough to get the data off: freeze your hard drive. http://www.daniweb.com/techtalkforums/thread9069.html
Unread 28-05-2007, 16:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I used to work for the technology department for the local school district, and as a last resort, we'd do the same thing. But yeah, I'd only try it as a last resort.
Unread 28-05-2007, 15:44
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Have you tried Drive Genius or Data Rescue II? (kyle beat me to it)
I've used both and they work beautifully.
EDIT: I've also tried disk warrior. Works fine. I've been through several mac crashes..... (I'm not very nice to my HDs)
Jacob
Last edited by whytheheckme : 28-05-2007 at 15:46. Reason: kyle beat me to some stuff
Unread 28-05-2007, 16:04
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Somewhat, Mac OS X has a single user mode (http://docs.info.apple.com/article.html?artnum=106388) like Linux does. However you would need to know some Unix commands to perform some disk checking functions like fsck.
But when you can't mount a disk, that solution wouldn't work anyways.
But before you send you HD, always check a couple of things.
1. Take out your HD and mount it using an external solutions. You would be surprised to see how many times cables and connectors burn out. This is especially true of notebook cables, but they typically use very thin ribbon cables.
2. Check to see if the disk has directory damage, using a product like Disk Warrior
I would stay away from freezing your HD. Typically that doesn't work (well at least for me).
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Need help recovering corrupt .3dS files and backups. Nimmy 3D Animation and Competition 9 09-02-2006 22:30
Need help with Data recovery [urgent] plutonium83 Chit-Chat 7 11-01-2005 10:35
Recovering code from the RC Orborde Programming 15 04-12-2004 20:02
