Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 28-05-2007, 18:39
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: HDD crash, need help recovering data!
If you can get the disk to at least spin up, and if there is physical damage to the disk, you you can try using the UNIX command dd to physically copy everything as is into a disk image.
http://www.macosxhints.com/article.p...50302225659382
For everyone knocking off Macs here, I use both Windows and Mac about equally. And every time I've ever had a sketchy/dead hard-drive (or CD, or other storage media) with either corrupt data or physical damage, Mac OS X has always been able to recover more of the lost data than Windows. (Especially if you go into the Terminal window and start using UNIX commands.) Windows usually stops reading the drive as soon as it finds physical damage, but Mac OS X is much more tolerant and will keep on reading the data, trying to recover as much as possible.
But to be fair, I'd assume that any UNIX-based operating system (including Mac OS X and Linux) would preform about the same.
Art Dutra IV
世上无难事,只怕有心人.
Unread 28-05-2007, 23:25
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I just remembered!
I used to use Norton Utilities when I ran Mac OS9 on my PB Ti. There is a new X version out. That seemed to work beautifully. Just pop the disk in, it boots off of it, select the drive, and BAM! Repaired. (Hopefully)
Jacob
Need help recovering corrupt .3dS files and backups. Nimmy 3D Animation and Competition 9 09-02-2006 22:30
Need help with Data recovery [urgent] plutonium83 Chit-Chat 7 11-01-2005 10:35
Recovering code from the RC Orborde Programming 15 04-12-2004 20:02
