Go to Post Good luck, and may the FIRST be with you. - Leav [more]
Unread 30-05-2007, 01:27
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Spur gear to go CIM for 56mm Banebots
I need to know a few specs of the 56mm gear that goes on the CIM for the banebots transmission they are:
diametric pitch (dp)
# of teeth
pressure angle (pa)
bore size (inside diameter)
length (or face width
material
-John
Unread 30-05-2007, 01:45
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Spur gear to go CIM for 56mm Banebots
DP: 32
#Teeth: 20
PD: 0.625 in
Length: 0.75 in
PA: Unknown (probably 14.5 degrees)
Material: Unknown
Can anyone fill in the unknowns?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 30-05-2007, 12:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There's a bit here.
By the way, the gears are 0.8 module (metric), which is equivalent to 31.75 pitch, and will mostly work with 32 pitch gears for our purposes. Also, since it's metric, the pressure angle is very likely 20°.
Unread 30-05-2007, 12:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
If you're so inclined, one supplier of .8 module spur gears is www.pic-design.com
Years ago, this company was able to provide difficult to find .7 module gears to mate with the Bosch drill outputs, as some may recall.
--Madison--
...down at the Ozdust!
Unread 30-05-2007, 13:01
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Finding 0.8 module gears is not the easiest thing to do.
Pic Design has a stainless steel 0.8 module, 20 tooth, 20 deg.p.a. gear, but it has a 10mm bore: MSG29-20 (although, I could only find it in my hard copy catalog)
Misumi has a stainless steel gear, same specs but with a 6mm bore: GEABS0.8-20
QTC has a carbon steel gear, 6mm bore: SSCP2.5-20
Stock Drive Products has one that may be perfect, with an 8mm bore: S10T08M020S0508
All of these part numbers were found through www.globalspec.com.
BaneBots won't sell these gears individually?
Andy B.
Unread 30-05-2007, 13:45
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Nope I tryed contacting them they said that because of how they get the parts they cannot sell parts individual from the "kit"
-John
BaneBots 56mm Gearbox - Second Stage Sun Seizing Gary Bonner Motors 18 10-02-2007 12:52
New Banebots 56mm transmissions for sale fsracer Motors 1 07-02-2007 22:58
pic: 166 CIM Support Bracket on 56mm transmissions Dan Petrovic Extra Discussion 5 28-01-2007 18:42
Spur Gear Rod? David Guzman Technical Discussion 6 18-01-2006 22:53
Gear Ratio Math for Cim Motor FP801-005 KogaVanDragon Motors 2 14-01-2006 02:38
