Go to Post Be the change you want to see. - staplemonx [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
  #31   Spotlight this post!
Unread 26-05-2007, 22:51
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Talking Re: Optimizing Air Cannon Range
Originally Posted by EricRobodox View Post
well, we made one, just did not get the valve working the way we wanted. Pressure was ok, just the valve we used didnt fire fast enough. We scrapped it.
You need one of these valves.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
  #32   Spotlight this post!
Unread 27-05-2007, 01:03
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Its a shame your trying to launch T-Shirts. To increase the range in my cannon I just use water.
I propelled an aluminum baseball bat over 300 yards with 135 PSI and about .5 gallons of water.
  #33   Spotlight this post!
Unread 30-05-2007, 20:07
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Aluminum baseball??
Edit: opps misse the bat lol thought you were talking about a ball
  #34   Spotlight this post!
Unread 13-09-2008, 09:38
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
Post Re: Optimizing Air Cannon Range
a little Info about that Rain Bird sprinkler valve, it does RECOMMEND a 24VAC power supply. the transformer is pretty simple design on the inside, first get a 12VDC to 110VAC adapter, like the one you plug into a car's lighter port, a project box, probably available @ Radio Shack, some 16 gauge wire, NOTE: i would recommend two DIFFERENT colors for the positive and black as both the negatives, just remember which negative went where. and a 110VAC to 24VAC adapter, FYI: it NEEDS to have at least 16 gauge wire. Now if you don't want to take the car adapter apart, then goto an auto store and get a 12VDC accessory port. attach the 12VDC accessory port to a SPIKE, plug the 24VAC adapter into the 12VDC to 110VAC adapter, plug this into the accessory port connected to the SPIKE, then the Rain Bird valve to the transformer you just made and wallah!!!!, you have hopefully just made your valve work at its best.
If anyone has extra ?'s send me a message anytime you feel the need.
  #35   Spotlight this post!
Unread 14-09-2008, 20:11
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
i know this thread is about t-shirt cannons, but what else have you tried firing? 1-2 years ago me and a few friends on the team discovered that pencils make great projectiles when stuffed into pvc pipe. were able to get them to fly at least 100ft. although this is always fun, its bit dangerous, and we tend to do it when we should be working on the robot.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
pic: Toltech Air Cannon Prototype Andrew Schuetze Extra Discussion 2 29-05-2007 15:29
FIRST air cannon robots PVC?? Andrew Schuetze Pneumatics 40 03-01-2007 15:16
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
