Go to Post There are "Problems", and then there are "Solutions". Understand the Problem, and keep your mind open to alternative solutions. Don't get married to a Solution. - rich2202 [more]
Unread 30-05-2007, 21:10
in between teams
AKA: Luke Van Oort
Re: Single Click On/Off Using the Trigger in EasyC
I dunno if this is causing the problem, but I'd put in a little time delay before it can switch states, because, as coded, if you held the trigger down too long the system would 'flicker' between the two states.
I have no experience with WPIlib, so I do not know if this could be the issue, but you don't set the relay to zero in your second if statement, so I would think it might just stay at that value set earlier. Again, I have no experience with WPIlib, so I don't know if this could be the issue.
Team 1219: 2009 - Mentor
multiple autonomous modes using easyc cerberus170 Programming 3 20-02-2007 15:01
Using printf() as UserCode in EasyC 2.0 tacman1123 Programming 2 31-05-2006 10:01
Using SMC Single Selenoid Valve from last year? Sachiel7 Pneumatics 3 20-01-2005 21:31
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
