Go to Post FIRST is like Starbucks coffee, it's addicting and you just can't seem to get away from it... - Beth Sweet [more]
Unread 30-05-2007, 20:36
IraJason IraJason is offline
In Search of "Bang Head Here" Sign
AKA: Ira Goldberg
FRC #3632 (D-Tecs); FRC #1712 (Dawgma)
IraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant future
Send a message via AIM to IraJason Send a message via MSN to IraJason
Single Click On/Off Using the Trigger in EasyC
I've posted a few pictures of my senior project, and before my presentation I've been working with Easy C to get the cathodes that are attached to my robot to light up and stay lit after a single click of the left trigger. I then wanted the cathodes to turn off once the trigger was clicked again. The cathodes are connected to the RC using a Spike Relay. I have been using EasyC to program my robot. I do not have the laptop that is used for programing with me but I believe my current code is:
if(p1_sw_trig && n == 0)
OItoRelay(1,1,1,1);
n = 1;
if(p1_sw_trig && n == 1)
n = 0;
This turns the light on with a single button click, but the cathodes do not always turn off with the next click. I was wondering if anyone knew how to make this work, rather than have it work half the time or using two buttons to turn it on and off. Thanks in advance!
-Ira
Many respectable physicists said that they weren't going to stand for this - partly because it was a debasement of science, but mostly because they didn't get invited to those sort of parties."
-Douglas Adams The Hitchhiker's Guide to the Galaxy
2007 Galileo #6 seed, 5th Alliance Captain, Semi-finalist
2007 Philly Regional #4 Seed, Philly Regional GM Industrial Design Award Winner
2006 Philly Regional Highest Rookie Seed,Philly Regional Rookie All Star
Unread 30-05-2007, 20:52
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: Single Click On/Off Using the Trigger in EasyC
I've never written C where && means both values are equal to the value on the right of the ==. I've always done it if (p1_sw_trig == 0 && n == 0)...
Maybe try that?
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 30-05-2007, 20:53
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
This how we did a click on click off
    if(CLAW_BUTTON == 1 && claw_toggle_state == 0)       // Code to handle toggle
        CLAW_OPEN = !CLAW_OPEN;
        CLAW_CLOSED = !CLAW_CLOSED;
    claw_toggle_state = CLAW_BUTTON;
Unread 30-05-2007, 20:54
in between teams
AKA: Luke Van Oort
Maybe try that?
Since the value of a trigger is already essentially a boolean you can just use it as itself, no == needed. So what he has is the same thing as (p1_sw_trig == 1 && n == 0)
Team 1219: 2009 - Mentor
Unread 30-05-2007, 20:58
AKA: Ira Goldberg
Yep, I have the variable p1_sw_trig set when the trigger is pressed.
Unread 30-05-2007, 21:10
in between teams
AKA: Luke Van Oort
I dunno if this is causing the problem, but I'd put in a little time delay before it can switch states, because, as coded, if you held the trigger down too long the system would 'flicker' between the two states.
I have no experience with WPIlib, so I do not know if this could be the issue, but you don't set the relay to zero in your second if statement, so I would think it might just stay at that value set earlier. Again, I have no experience with WPIlib, so I don't know if this could be the issue.
Unread 30-05-2007, 21:24
AKA: Ira Goldberg
It has been a few months since I've done computer programming, so from what I'm getting now, if the button is pressed and the claw_toggle_state = 0, and CLAW_OPEN and CLAW_CLOSED becomes not what it's previous state was. The claw_toggle_state then becomes 1 when it is pressed.
This means in my code I should have:
if(p1_sw_trig && cathode_toggle_state == 0)
    OItoRelay(1,1,1,1);
cathode_toggle_state = p1_sw_trig;
I think that should be right, but feel free to correct me.
Unread 30-05-2007, 21:29
AKA: Ira Goldberg
I was thinking that was the problem, as I tried using a counter for every button press and it still didn't work all the time. I'll try putting in a little bit of a time delay during the second if statement and see what happens.
I also tried setting the relay to zero in the second statement, and the results were not too good. I don't remember the exact response though. This current code does work, but I am missing a step in turning it back off. It does turn off on some presses, but sometimes it does not for a few or many clicks.
Unread 30-05-2007, 22:41
You don't really want to toggle the state of the lights when the trigger is active. You want to toggle when the trigger becomes active. You need to keep track of whether or not the trigger is pressed, and only do the toggle action when it is pressed now, but was not pressed last time.
The code bear24rw posted is a good example of how to do it.
Unread 30-05-2007, 22:59
AKA: Ira Goldberg
I'm still very much a beginner at programming for a robot, and haven't really coded anything in the last few months. If it is at all possible, can someone give a breakdown of the code that Bear24rw posted. I just want to make sure that I understand what is going on, as I am still a bit fuzzy. Thanks to everyone who's helped me so far!
Unread 31-05-2007, 00:58
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
When I need to do something like this I write the program so that it waits until the first cycle after I let go of the button to toggle it. This way it is like:
if (pressed)
     if (not pressed)
     toggle;
Unread 31-05-2007, 09:11
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
This is how we do it, although we have since developed and function call method that is a little more sophisticated than this sample. But this sample does work.
static unsigned char p1_sw_trig_prev = 0;
if ((p1_sw_trig == 1) && (p1_sw_trig_prev == 0))
relay1_fwd = !relay1_fwd;
p1_sw_trig_prev = p1_sw_trig;
So what is all of this and what does it mean...
1) We define a static variable to hold the contents of the state of the button to be compared with on the next pass through the program loop.
2) We say if the trigger is being pressed and was previously in a released state then change the state of relay1_fwd. But if not don't do anything.
3) The relay1_fwd = !relay1_fwd statement causes relay1_fwd to change states. If relay1_fwd initially was zero, it becomes 1 and vice versa.
4) We then save the state of the trigger in our static variable to use in the comparison next time through.
What will happen now is every time you pull the trigger and release it will case the relay1_fwd to toggle between on and off.
What you are accomplishing here is making your trigger into a toggle switch of sorts. Click once it's on, Click again it's off, click again it's on, click again it's off and so on....
I hope this helps you to understand better what is happening.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 31-05-2007, 10:58
AKA: Ira Goldberg
Thank you very much for the full breakdown! I'm pretty sure I can do this now. Thanks to everyone for all their help and I'll post about my results once I get the code loaded on the robot.
Unread 31-05-2007, 18:21
AKA: Ira Goldberg
Ok, I got the code to work, bit it took a little bit of tweaking. It may be how I set it up though. Either way, I'm able to have the cathodes toggle on and off with the trigger. This is the code I used:
if(p1_sw_trig && toggle_state == 0)
   toggle = !toggle;
delay(100);
if(toggle == 1)
   OItoRelay(1,1,1,1)
For some reason, without the delay, the program would have the light stay on only when the trigger was held, then not do anything on the second click. On the third click however, the cathodes would stay on after the trigger was pressed. I think it has to do with the amount of time you hold the button down, but I'm not entirely sure. If someone does have an answer to that, it would be greatly apprciated to know for future projects. And again, thank you to all who contributed to this! Doing beginners programming on a computer is a bit different than programming for a real world object.
Unread 01-06-2007, 00:29
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Even though I'm not a C programmer, I've done this with my TI-89 before when making a program...
It would be something like this I guess
//NOTE: THIS IS NOT C CODING AT ALL AND IF YOU USE THIS, YOU WILL GET ERRORS!!!
define lastvalue //lastvalue can be any variable
 define cathodespike //this would be replaced by the particular spike you will have set to control your cathode
do:
if lastvalue==(not equal)p1_sw_trig and p1_sw_trig=1 cathodespike=1 then
   cathodespike=0
   lastvalue = 1
endif
if lastvalue==(not equal)p1_sw_trig and p1_sw_trig=1 and cathodespike=0 then
cathodespike=1
lastvalue = 1
endif
lastvalue = p1_sw_trig
loop
With this code, there is no delay and no chance of the light blinking on and off if the trigger is held in a closed state.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
multiple autonomous modes using easyc cerberus170 Programming 3 20-02-2007 15:01
Using printf() as UserCode in EasyC 2.0 tacman1123 Programming 2 31-05-2006 10:01
Using SMC Single Selenoid Valve from last year? Sachiel7 Pneumatics 3 20-01-2005 21:31
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
