Re: Illegal?
), and will have white cathodes there if we can't see enough with the UV lights. So the lights will only be seen when we "open the hood".Quote:
. Will not use green whatsoever.Quote:
-So far so good, thanks a bunch for the quick replies. ![]() |
Re: Illegal?
Those cathodes shouldn't be that hard to wire in. I wound up putting connectors on mine and attaching them to a Spike. Just have it programmed to have that Spike turn on when you want it to and that should do it.
Re: Illegal?
OK guys, I do not believe that CCFL tubes on the robot pass the flow chart and would not have allowed them during the inspection process. Sorry, but should they break, the materials are hazardous and the power supply is 680 volts!
The super brite LED also would not pass as this device is likely to over drive the camera making it impossible to see other colors. The lighted fan does pass inspection as long as it is 12 volts supplied from a 20 amp circuit breaker and does not pose a vision system threat. I have allowed them in the past. I believe that the ban on hard drives was based on the idea that this motor gave the team an advantage. I, however, would like to see this thought changed as a drive might make for an interesting application since single board computers obviously pass as custom circuit. <R47> Additional electronic components for use on the ROBOT must be either COTS items, or assembled from COTS items. Everyone uses tubing for a variety of purposes especially heatshrink. What it is used for may be disallowed during inspection so make sure your intended use fits the robot rule book. |
Re: Illegal?
Re: Illegal?
1> While the ballast of the CCFL does boost the voltage to 680vdc, that is not against the rules, nor is it a safety hazard as long as the proper wiring / curcuit breakers are used. 2> Many items, on a robot, could be considered hazardous if broken. As long as the CCFL tube is intact, it is not hazardous materials. The key on this point is to ensure that it is well protected and that parts will not escape the robot (IE completely contained) should it break. 3> unless you place the 'super bright' LED directly in front of the camers, it will not have enough lumens to 'wash out' the CMU camera. If what you were saying was true then the 'stadium lights' would always wash out the cameras (instead of every once in a while) and cause them to never work because they are far brighter than a super bright LED. JMHO. |
Re: Illegal?
didnt team 40 use LEDs, not cathodes
#7
Re: Illegal?
Yes, we used red and white LEDs, covered with plastic shielding to dampen the brightness of the LEDs. They lit up when the robot was close to a tube.
#8
Re: Illegal?
Send me some specs and a link to where you picked them up Jess!!! I want to brighten some things up as a side project... AND... The Cavalier wants to be nice and bright for some CT summer night cruising. ![]() |
#9
Re: Illegal?
195 used almost those exact fans on our 2006 bot. We had 2x 120mm fans with 4 blue LEDs cooling our transmissions CIMS. The fans passed inspection at a regional and at nationals.
#10
Re: Illegal?
Daniel,
Besides the fact that the inverter puts out a very high voltage and requires better insulation on wiring than that provided in the kit, there could be any number of reasons to prevent it's use. The inverter should be considered a custom circuit and therefore can only feed the RC under the robot rules. <R61> All outputs from the custom circuits must connect to the Robot Controller or to other custom circuits. You might claim that is a non-functional decoration but decorations can only draw power from the 12 volt main battery, the inverter is the power source to the lamp, not the main battery. <R110> Decorations may draw power from the 12v electrical system as long as they are powered via a dedicated 20A or 30A circuit breaker and do not affect the operation of other control system components. You might even argue that custom circuits can and frequently do have local power supply regulators and/or negative power supply generators, but again the voltage is not higher than the main battery and those devices still follow the rules for custom circuits. The lamps themselves are not roboust as anyone who built lights in 2006 can attest. I would venture to guess that several hundred lamps gave their lives to an errant ball during last year's game. Broken lamps produce dust and slivered glass. I wouldn't want to do a belly check on a robot and lay down in a pile of phosphor and glass out on the field. Small, intense, light sources play havoc with CCD cameras especially those without an iris mounted in front of the pickup. The particular device linked in the first post is a "black light" or ultra violet output device. Although it has some visible light output, there is considerable radiation outside the visible spectrum. CCD pickups are capable of detecting a rather wide spectrum including IR and UV and this device would likely cause some interference. Sorry, but I have to stand by my original response. Really cool but not for use on an FRC robot. |
#11
Re: Illegal?
Hmm... well... good points (as usual), Al. I would have assumed that properly protected blue or red cold cathode tubes would be okay (assuming green is the only target), but you've got a point about the transformer pumping the voltage up. Although I would suggest that some reasonable level of LED lighting in a colour (or spectrum range) different from any vision targets should be okay, I would suggest teams make a point of clearing up any potential misunderstandings in the Q&A forum next year before decorating a robot with shiny flashy things.
I would suggest to anyone terribly disappointed by the concept of having cold cathode tubes potentially nixed at tech inspection that they consider lightsticks, such as cyalume http://www.cyalume.com/ They are plastic, chemoluminescent tubes... crack them and shake them at the start of the day and they should last for several hours of cool glowing robotness on the field, and in the pits... without draining batteries, or exposing anyone to high voltages, or the potential for cracked glass on the playing carpet. Jason |
#12
Re: Illegal?
As long as it is breakered properly, then electrically it should pass inspection, according to the letter of the rules. Quote:
For LEDs I disagree. I can see plenty of feedback information that could be useful here. But I would caution those who would use them to be prepared to prove that your setup does not affect the CMU camera in any way, and to be prepared to disable the LEDs should you be required to do so. Last edited by Daniel_LaFleur : 05-06-2007 at 09:42. Reason: formatting |
#13
Re: Illegal?
I have to caution you, you are mixing apples and oranges here. Wattage is not the issue. 680 volts to exposed skin on students, volunteers and mentors is the issue as well as 680 volts to robot frame when the lamp breaks and the cathode touches the frame. I will grant you it is low current but I bet you wouldn't like it if you touched the exposed voltage. There is a difference between safe primary wiring practices and exposed high voltage. On the camera, I am speaking from my everyday television experience. Small bright light sources are especially nasty to CCD pickups because the the AGC circuits and other electronics tricks used to get a nice looking picture are confused by bright spots in a normally lit frame of video. There are no optical filters before the pickup so all light reaches the face of the pickup where there are individual pixels for the three colors. Most light sources are fairly broad in their spectrum but LEDs can have some rather narrow bandwidths. A white super bright LED for instance has a rather high peak in the blue spectrum and a rather broad peak in the green. That being said, a small bright light produces a sharp image on the face of the pickup which for a variety of reasons, leaks light through the surface of the sensor and also reflects light on the back of the lens which then in turn sends it back to adjacent areas of the pick up. Besides the effect it has on the pickup, the circuitry used for making video outputs and the adjacent leakage paths, the signal then has a significant impact on white balance and local heating on the face of the sensor. All of these things aggravate the ability of the sensor to determine the presence of the correct color light. Add to that the 60 degree field of view of the lens and you are now producing problems that most teams will not be able to overcome. Last edited by Al Skierkiewicz : 06-06-2007 at 07:31. |
#14
Re: Illegal?
From someone who has been zapped by a transformer from these things I must say it hurts like a .... well it hurts a lot is what I'm trying to say. Its not likely a lethal amount but it certainly cause issues when trying to remove a robot or get to the power switch on the bot. With using UV lighting, there is certainly a problem with the CMUcams, when I brought the CMU can home to work with it I had issues with it getting distracted by my computer which is lit with UV CCFLs. This occured at a distance of roughly 3 feet. It is also important to note that the CMUcams are quite sensitive to a number of wavelengths and things such as too much red or blue can affect its ability to see green. There is an up and down to using a color in the "center" of visible light in that it is strongest and easiest tosee but it is also the easiest to interfere with.
#15
Re: Illegal?
| pic: How illegal is that? | Arefin Bari | Extra Discussion | 40 | 16-03-2007 16:00 |
| Illegal human player bin placement | Mike Soukup | General Forum | 29 | 01-04-2003 21:17 |
| Illegal material | PDonovan | Rules/Strategy | 13 | 16-05-2002 16:53 |
| Illegal use of springs? | HotWheels2002 | Electrical | 12 | 16-04-2002 23:14 |
