Go to Post Give me enough gearboxes and I'll move the world. - SenorZ [more]
Unread 03-06-2007, 16:34
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
Lightbulb Why Not Use ISM band?
How come no one has thought of using ISM band radios at 2.4 Ghz. It provides a strong signal and ranges up to 3,000 feet. Radio problems seem to happen a lot at compition. Spektrum has come out with their "DSM" (Digital Spectrum Modulation) radios for rc cars and works awsome, also no easy to damage metal antenna.
"Because of the relatively low noise in the ISM band, and the noise immunity inherent in DSSM systems, Spektrum DSM is said to be free of "glitching" (momentary corrupted or missing signals which can cause erratic movement or loss of control). Additionally, the system "binds" each transmitter to its particular receiver, ensuring that no transmitter will interfere with other nearby Spektrum DSM systems."
also, i can see the radio being more compact and useing one of the I/O pins insted of a big heavy serial cable.
I see in logic, Black and White
Why you should use Gmail Nathan Chit-Chat 5 22-02-2007 00:20
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
Why would you use FIRSTwiki? Max Lobovsky FIRSTwiki 4 18-07-2004 23:59
Why (not) flash? tchescow Website Design/Showcase 10 04-01-2004 16:29
Non - GP-ism at SVR CaseyG668 Regional Competitions 18 27-04-2003 15:08
