Go to Post Secure your battery well, or it will fly like a fish. - Nate Laverdure [more]
Unread 03-06-2007, 16:34
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
Lightbulb Why Not Use ISM band?
How come no one has thought of using ISM band radios at 2.4 Ghz. It provides a strong signal and ranges up to 3,000 feet. Radio problems seem to happen a lot at compition. Spektrum has come out with their "DSM" (Digital Spectrum Modulation) radios for rc cars and works awsome, also no easy to damage metal antenna.
"Because of the relatively low noise in the ISM band, and the noise immunity inherent in DSSM systems, Spektrum DSM is said to be free of "glitching" (momentary corrupted or missing signals which can cause erratic movement or loss of control). Additionally, the system "binds" each transmitter to its particular receiver, ensuring that no transmitter will interfere with other nearby Spektrum DSM systems."
also, i can see the radio being more compact and useing one of the I/O pins insted of a big heavy serial cable.
I see in logic, Black and White
Unread 03-06-2007, 18:07
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: Why Not Use ISM band?
I have a feeling we might see 2.4GHz radios in the new control system. For MIT's 2.007 competition, we switched over to ZigBee serial bridges this year. They're cheap, easy to use, have good range, and worked very well overall. But no radio can be entirely free of glitches: we found a slight increase in dropped packets in the presence of 802.11g wireless networks. The current 900Mhz radios probably don't have this problem.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 03-06-2007, 19:11
REVving up for a new season
FRC #2848 (All-sparks)
Originally Posted by Mr-Shutter View Post
Radio problems seem to happen a lot at competition
Unfortunately this is a big misconception. In actuality the radios which are used on the robots and the field is one of the most stable parts of the control system. Most cases where people blame radio problems for robot malfunctions are actually other un-related issues, such as battery power, programming mistakes, and mechanical failures. I challenge everyone to actually look at their robots when a problem happens rather then just blaming it on the radios.
Specifically when dealing with the change over between autonomous and teleoperated modes make sure that your variables and states are set correctly.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 03-06-2007, 21:24
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I'll second what Greg said. I wasn't that involved in FIRST in the 2007 season, but during the 2002-2006 seasons (which included 10 regionals that I competed in) I never encountered a radio problem that was caused by interference or signal issues. All the problems I encountered were caused by loose cables, bad code, scoring system problems, etc. I know the new 2007 radios had issues, but from what I understand those were mostly worked out.
Zan Hecht
Unread 04-06-2007, 07:34
Everyone,
Your radio links are monitored during competition and if there is a radio issue you will be notified. Most often a lead inspector will carry the message and help you look for problems. I had far less radio issues this year then in the past once the new code was loaded into the radios. Most radio issues come from kinked or otherwise abused cabling, mounting of the radio deep inside the robot base or next to a motor, or battery issues.
Unread 04-06-2007, 20:56
DonRotolo's Avatar
Back to humble
FRC #0832
I agree, the radios used by FIRST are pretty bulletproof, and they do error detection so missing data is very rare. 900 MHz (which, by the way is also an ISM band) is a somewhat underutilized band these days, so it's a lot quieter than 2.4 GHz ISM.
Don
Unread 05-06-2007, 17:31
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
I agree with those that said the radios we have are very robust. We had quite a few issues with lag in the controls or dropping signal pre ship date. But once we got to the regional and had the firmware on the radios and RC updates everything was flawless no more lag and I don't think we ever dropped the signal after that.
I think I'm beating a dead horse now but the radio modems we have now certainly seem to fit perfectly to most of our needs(yeah being able to send massive amounts of data back to the OI would be nice for stuff like video but its not needed and won't really be utilized by many i don't think)
KK4KQO
http://voltair.us
Unread 06-06-2007, 19:53
Mr-Shutter's Avatar
Audiophile
AKA: David
Do they have to be so big?
Unread 06-06-2007, 21:03
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
The number one "radio problem" I saw at two regionals, the champs and two off-season events this year was forgetting to plug the serial cable into the RC. Somehow I don't think new radios are going to eliminate that problem...
Just the same, the smaller packages and more robust antennas used at 2.4 Ghz would be nice - especially compared to this year's radios.
Pete Kieselbach
Why you should use Gmail Nathan Chit-Chat 5 22-02-2007 00:20
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
Why would you use FIRSTwiki? Max Lobovsky FIRSTwiki 4 18-07-2004 23:59
Why (not) flash? tchescow Website Design/Showcase 10 04-01-2004 16:29
Non - GP-ism at SVR CaseyG668 Regional Competitions 18 27-04-2003 15:08
